Jack
I can tell you that things are a lot easier and more precise than how I use to fix things.
Here is my early milling machine. I would hold the vise with my hands and move it under the carbide burr.
In this picture I am making a spacer for my back axle on my 74 Sportster Chopper. The right side of the picture is the backstop for my buffer. (6"grinder with a buffing wheel). I wore out one buffing wheel polishing parts for my bike.
:O
My other shop, when it was my only shop. With the 74 in the early stages of getting redone.
Finished.
Things got done, just the tools dictate what I can do, verses what others had to do for me.
This bike is now in pieces, as it needs some work to seal up the motor. I need to split the cases to do the repair.
I bought a basket case 73 Sportster a couple of years ago, for parts for the 74. I figured I would rebuild the 73 and learn to do the motor work, so I could do the work on the 74 with the knowledge I got doing the 73, with out messing my chopper up. Every time I got ready to rebuild the 73's motor I ended up buying machine tools, starting with the lathe, and would have to wait to get more funds. This has been going on for the last year and a half. Now I have a lathe,shaper and a mill with tooling. The mill I did not intend on getting untill I built the 73, and sold it for the funds, to buy the mill, but the deal was to good to pass up, when it came.
Sanford and Sons is closed for now, I am not buying anymore machines for awhile.
I am now starting to build the motor for the 73. I am going to a friends tomorrow and am going to learn how to put the lower end together. I do not have the tools, or knowledge for this, so I am paying him to teach me how to do mine. The motor, will get a new main shaft, rod bearings, and rings. The jugs are in good shape and will just get honed. The heads have come back from the motor shop with a new valve job, and are ready.
Tonight I installed, and reamed the bushings for the shifter shaft. I made a bushing installation tool, from some scrap. I used it and the mill to press the old ones out, and the new ones in. Pressing the old ones out was quite easy. Pressing the new ones in was a little more exiting. The tool I made for doing the pressing, worked real well pressing the old ones out, as the bushings were well worn. Pressing the new ones in, the tool got hung up in the part, as I had made it just a nice slip fit in the bushings, not leaving enough room for the compression of the bushing. I got it all apart with out damaging any thing. I turned the diameter of the tool down just a bit more, and every thing went well.
Here are the pictures.
I started with a short socket for support, but had to use a deep well for clearance of bushing lenght, but this it the way it was done, just holding the cover by hand.
New bushing in the cover.
New bushing in the engine case. The cases are put together, mounted to the mill table and indicated with a coaxial indicator, so as to press the bushing in straight.
A picture of the setup, with the cam cover installed, ready to ream.
Both bushings line reamed, and ready to go.
