Patio's projects
Moderators: Harold_V, WJH
Re: Patio's projects
Post by BadDog » Thu Mar 26, 2020 4:32 pm
The collet closer (a very nice Royal unit) for my old Rockwell 11 had the threads just completely worn out of it. It had spent it's production life with a turret and running as a chucker, so no appreciable bed/saddle wear. A very good thing, but I digress.
I bought a piece of common DOM tube of appropriate size and made a duplicate of the one I had. Since it fit through the headstock, working with it was trivial, and it was the first time I ever did ID thread! All came out very well, and the guy who bought my Rockwell is still using it.
Patio
Post by Patio » Mon Apr 06, 2020 12:09 pm
Collet closer is done. I am working on a tool post base at the moment. I will post more about it all, when I get a moment. But for now, here is a teaser.
Dovetail cutter, I made for the project.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Patio
Post by Patio » Thu Apr 16, 2020 12:43 am
Hello everyone, I hope this finds everyone safe and with someone you love. :)
Thanks Jack. Yep it is nice to have a shop to goto.
Liveabaord, They just have to hold steady, and your good to go.
Thanks Gregg!
Harold, in large part to your input. :)
Russ, my path was not near as easy as yours, making this drawbar.
The last couple of weeks has been what it may be like in retirement. I have been enjoying myself in the shop. I have gotten to a point now, with the lathe, that I am moving on to other Round Tuits.
Here are some pictures, of the progress, that will cover a few post, for the amount of pictures.
The draw bar;
I decided not to use any part of the orignal draw bar. I got 4' of 1.125ODX.9??ID, DOM tubing. The first thing I did was cut it off to length, a few inches short. :shock: Soooo, I made it a two two piece assembly. Then I made that, a touch shorter than I would have liked, but it works as intended. :?
The collet end.
The upper one, is the original.
The peices.
Together.
Installed.
Continued in next post!
Forgive the past!
neanderman
Post by neanderman » Thu Apr 16, 2020 1:25 am
Pat, your humble acknowledgement that you are not infallible brings great warmth to my heart!
Here's to mistakes and not being ashamed to admit to them!
Stay safe, y'all. This is global -- we all have an equal stake in it.
Ed
Le Blond Dual Drive
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Patio
Post by Patio » Thu Apr 16, 2020 1:45 am
To have the collet closer installed, and still be able to open the cabinet door, I needed to punched out the inside sheet of the cabinet door.
This is a tool I use at work, as an electrician, that I like really well. I have a hydraulic set up also, but this is fast and clean.
That is it for the collet closer.
Coolant mister setup.
The mill came with a mist coolant set up on it. I have always just used it with air, to keeps the chips clear and a little bit of cooling. It was mounted to a plate that was just below the spindle handle. When not in use, (most of the time) it could get in the way. I decided that I would like it to hang off a rod, from the little hole on the right side of the mill spindle. Being my mill is an import, the threaded hole is 6X1mm, I made a thumb screw for it.
Then an aluminum plate was made to for the thumb screw on the unit, and a bar to hang it on.
Now I am able to, move it around, take it off easily, and use it for a tool post block, project, that has a good amount of metal removal in it.
Dove tail cutter;
This was made to cut the dovetail in the tool post block, allowing it to attach to the carriage of the lathe. More about that in a minute.
I recently made a good deal, on an Online Auction, for a 81 peice gage block set and a .062-.250 pin set, that both came in handy for this project.
Randy Richards a machinist on You Tube, makes these and sells them. He also has a video of, how he goes about making them. I once owned a real dovetail cutter, for about 5 minutes. I still have it, sans any flutes! This one was going to be much cheaper to learn on. :)
I used a sine plate to set the angles and used a gage pin the same size as the center hole of the insert, to locate it on the part, where the threaded hole for the holding screw was to be.
Turned basic shape, using the compound to cut the tapered section. It is not a critical dimension, one just needs the radius, where the insert will sit to be larger the one side of the insert.
Parted it off, put it in a collet block, put the collet block, with the part in it back into the 3 jaw chuck and faced the part.
Then to the mill, using the sine bar to get the angle right, so the bottom edge of the insert will be at a right angle to the axis of the cutter.
The finished project.
Forgive the past!
Patio
Post by Patio » Thu Apr 16, 2020 2:38 am
Tool Post Block;
In another online auction, I acquired a Dorian Quadra tool post, that was missing the handle. I bought a handle and it has since, sat under the table. It sits just a touch high when installed on my compound, to be able to use tooling that uses the entire slot, in the tool holders I have.
The compound connects to the carriage by a dovetail set up, and can be slid close or away, from the operator, as necessary for the tooling in the post. I decided to make a solid block for the tool post to sit on. This will have the advantage of a more rigid set up and creates a pallet, to which fixtures can be mounted, allowing for line boring, with the boring bar between centers. This disadvantage is I won't have a compound for threading. It is a fairly easy job to change the compound out, just two bolts.
This is what I started with. Bought it out of a local machine shop.
Machined it on all sides, unknowingly, making it just a little smaller than I had intended. :shock:
Removed about .300" off the bottom, using mist coolant and a 2", 3 flute, insert tool.
Cut the dovetail in one side.
Flip it over and drill all the holes, and making counter bores for the locking bolts. The hole for the tool post was located by setting the tool post where I wanted it on the block and then shaving some soap stone with a sharp edge, letting it rain down into the center hole, leaving a mark, once the tool post was removed. Being it is not a critical location, and point held in mill and some eye balling it, got things where they needed to be.
I gib was made for the other side to clamp the block to the carriage. I tilted the head on my mill, using the sine bar and gage block to indicate the proper angle.
Forgive the past!
Patio
Post by Patio » Thu Apr 16, 2020 3:00 am
Continued from previous post.
This is the angle milled on the gib. It was drilled and tapped for 3/8"X28 bolts. There are also a couple of pins, in the block, used to align the bolt holes of the gib under the holes in the block, for easy assembly.
I made the square head, 3/8"X28 bolts from grade 5, 1/2" bolts that I had. It was large enough for the .400" per side of the square head. I turned the head of the bolt first, then flipped it around and held it in a collet, for the parting off to length, turning to size and the threading.
The parts.
This is with it moved towards the operator on the carriage.
This is with it moved away from the operator on the carriage.
The completed set up with the tool post installed.
Forgive the past!
Patio
Post by Patio » Thu Apr 16, 2020 3:22 am
Now that I had all that set up, I still needed tool holders that would fit, four at a time. They are expensive to buy, so I just cut down some of the ones I had. I used the band saw to cut off the majority of the corner material and then use the face mill to finish to size.
Being they were import tool holders, they are not hardened. I found out the hard way that the Aloris ones are. I am now in need of a new band saw blade.
The control wiring;
Awhile back, I posted about the control mechanism that I had made for the lathe.
To complete that project I needed to pull the lathe away from the wall so I could get to the electrical cabinet and reconfigure the wiring, to make the controls and lights operate in the manner I wanted.
Here is the electrical cabinet, completed.
This the cabinet right below the electrical cabinet, that contains the hydraulic pump that feeds the headstock spindle and gear train. I use to feed the hydraulic "Variator Drive" mechanism. (Think hydraulic Reeves drive).
This is the end of this series of post. I hope it is not to much at one time, for everyone to digest.
The lathe is finally working the way I had hoped for a long time. Some day now, I am in a position to make a little, how it works, video of the lathe operations.
On to other projects now. I have been doing some sorting of my electronic piles and getting rid of stuff. Next project to tackle will probably be my never ending problematic Panhead motor. The weather is getting nice now.
Forgive the past!
Patio
Post by Patio » Fri Apr 17, 2020 5:04 pm
Another quick project.
This flashlight was given to me many years ago. It is my favorite flashlight. It quit working the other day, so I decided to see If it was fixable. It was. The switch works just like an ink pen, but the plastic part that held all the other parts, was broken. I was able to super glue the parts back together. The tricky part was getting to the switch. Sooooooo, I made a tool, to get it apart. Here is a picture of the tool and the flashlight. pins in the spanner tool I made, are about .047".
Forgive the past!
Post by NP317 » Fri Apr 17, 2020 7:58 pm
So many cool projects during this covid-19 shutdown!
I love being able to fix things like that.
Need a tool? Make one.
