Thanks! I appreciate the compliments.
I have good start on the next series of patterns. These are for the Lower Water Manifold (Part No. A27A, A28A & A29A)
Here is a photo of the pattern and core boxes for A28A. As you can see its a four part pattern with a follower. The core is four parts too
and is glued together with a lap joint.
Currently I am working on the pattern and core boxes for this piece (A29A) Lower Water Manifold Front Section. Once thats complete
I only have the rear section to do then I will be done with the pattern work for the piping. All that will be left are the mounts for the
sparkplug wire tube and the oil filler cap.
Here is what the finished piece will look like
