Edwards 5 Radial Engine
Moderators: Harold_V, JackF
Post by Harold_V » Sun Mar 09, 2008 4:50 am
Welcome aboard, Jim..
deadog
Post by deadog » Tue Dec 30, 2008 5:45 am
Hi All,
I am a new member and i am in the early stage of building the Edwards Radial 5, I am from Italy and I have all machines in my shop working in millimeters.It is a very hard unit conversion work,but...
I hope to succeed in.
A question : what about ignition system, spark plug ? I need help .
Daniele
tornitore45
Re: Edwards 5 Radial Engine
Post by tornitore45 » Fri Jan 11, 2019 11:06 am
I like to resurrect this old thread.
The Hoglet is almost finished and I am looking at the Edwards 5 drawings for the next project.
Sheet 5 The crankcase has 10 #6-32 Holes, 2 on each of the faces not occupied by a cylinder.
What are they for?
Would not oil leak out?
Mauro Gaetano
in Austin TX
siggy
Post by siggy » Fri Jan 11, 2019 11:34 am
Those holes are intended to be for the engine mounts. You can see the main mount ring with the arms attached to those holes in the picture at Image
Robert
tornitore45
Post by tornitore45 » Fri Jan 11, 2019 11:44 am
Thanks. That is a beauty. Looks like a sparker instead of glow.
Mauro Gaetano
in Austin TX
