Moderators: Harold_V, JackF
atsfsteam
Post
by atsfsteam » Tue Jul 21, 2015 9:26 pm
I do not have a manual for a Briggs & Stratton vanguard v twin 16 hp to find out Spark plug firing order. Does each plug fire on one revolution of the crank or one fire on one revolution and the other plug fire on the second revolution? I know that a Onan two cylinder fires both plugs on every revolution of the crankshaft.
atsfsteam on Tue Jul 21, 2015 11:17 pm, edited 2 times in total.
J.T. Bailey
Box Cab & 4-6-2 Pacific
SWLS,HALS & IBLS
hammermill
Post
by hammermill » Tue Jul 21, 2015 9:45 pm
with a single bearing on the crank both pistons are in time with each other i would expect on spark per rotation. the cam times the 2 180 deg apart.
file:///C:/Users/long/Downloads/B%20%2526%20S%20VanguardTwin%20Cylinder%20OHV%20Service%20Manual.pdf
manuals are readily avail online
ken572
Post
by ken572 » Tue Jul 21, 2015 10:58 pm
hammermill wrote:with a single bearing on the crank both pistons are in time with each other i would expect on spark per rotation. the cam times the 2 180 deg apart.
hammermill
Your link doesn't work
Ken.
One must remember.
Ken.
atsfsteam
Post
by atsfsteam » Tue Jul 21, 2015 11:14 pm
Link removed was not supposed to be there.
J.T. Bailey
SWLS,HALS & IBLS
ken572
Post
by ken572 » Tue Jul 21, 2015 11:56 pm
One must remember.
Ken.
ken572
Post
by ken572 » Wed Jul 22, 2015 12:32 am
One must remember.
Ken.
Post
by spro » Thu Aug 20, 2015 12:31 am
Your question was already answered by links. These engines seem good but were put in difficult situations. I had a post earlier about the stress upon the crankshaft in typical L/G tractors. Be forewarned if you see this. Well not that but another has seen what you may. Extreme stress on the vertical shaft. That is because the rest of the mower was junk. Harried homeowner had no other way to compensate for belt slippage than to tighten it further. The heat was warping the drive pulley and nothing could compensate for that. All this heat is delivered back into the engine.
Never should have been this way. One little step of another idler and slightly longer belt would have helped. But we are talking mowers which can't handle any taller than 5 or 6" without choking and gagging. The range was SO small. Then the mandrels units sucked bigtime and before they failed completely, put further stress on the engine.
Gee my little rant.. good engines unless they are being killed.
