Source of small diameter pistons and rings
Moderators: JackF, Harold_V
Bob Doris
Post by Bob Doris »
I have an IC project in mind and am seeking a source of pistons and rings in the neighborhood of 1 to 1 1/8 inches in diameter. Any help would be appreciated.
Jim_Popa_N_CA
Re: Source of small diameter pistons and rings
Post by Jim_Popa_N_CA »
Try the Otto Gas Engine Works at:
http://www.dol.net/~dave.reed/ringcost.htm
jpfalt
Post by jpfalt »
You could also check out repair parts for string trimmers as several are in the 24-30mm diameter range. If you go with commercial trimmer parts, most use two piston rings in an aluminum piston. Wrist pins rin around 8-10mm and most have needle bearings available for the connecting rods.
hendv6
Post by hendv6 »
Small rings>>> Check Otto gas engine, they should have what you need
Bob Doris
Post by Bob Doris »
Thanks all for the leads. These are new sources for me to investigate.
