Edwards 5 Radial Engine
Hi all
I have started building the Edwards 5 Radial Engine and I thought I would post the progress as I build it.
I have a few parts finished and posted photos at photobucket.
http://smg.photobucket.com/albums/v67/i ... %20Engine/
I will post updates as I complete other parts.
Regards
Ivy McNeil
ivymcneil@yahoo.com
Regards
Ivy McNeil
ivymcneil@yahoo.com
Re- Edwards 5 Engine
Hey Canyonman
The holed are vents, crankcase and oil tank.
Ivy
Ivy
- Attachments
- rear view.jpg (73.03 KiB) Viewed 29531 times
Ret. Machinist/Toolmaker
I did not fail, I just found 10,000 ways that wont work.
Hi Again
I finished the cylinder barrels, screw holes/polished/and finish
turned base dia.
I had a little trouble with the fins, the lathe tool loaded up and
moved a couple of the fins a little bit, if it looks to bad when I
start assembeling them I may make a new one.
Here is a photo.
http://img.photobucket.com/albums/v67/i ... 001453.jpg
Regards
Ivy
turned base dia.
Here is a photo.
Regards
Ivy
Hi Randy
I cut them on the lathe, they are .040 wide and .250 deep I ground my own parting tool.
I am working on the heads now and they have fins that will need to be machined with slitting saw and rotary table because of ports.
Ivy
Ivy
Hi All
I have the the heads in the works now, I have to install the valve
guides, machine the seats and intake/exhaust ports.
Still lots to do.
http://img.photobucket.com/albums/v67/i ... head-3.jpg
http://img.photobucket.com/albums/v67/i ... head-2.jpg
Regards
Ivy
Still lots to do.
Regards
Ivy
Thanks for posting the photos, really great work. I began the Edwards engine myself recently as a first major project, I've only done the cylinders and liners so far. My lathe is a lot smaller than yours, an SB 9C, no power crossfeed. I can't tell you how many grooving tools I broke doing the fins ! I was going to tackle the cylinder heads next and here's where I have a question for you. Looking at the diagram, the valve guides seem to be integral with the head but yours seem to be separate parts. What material did you use for them and are they a press fit ?
Paddy O'S.
Hi Paddy
I'm glad to hear from someone else that is building the Edwards 5.
It will be nice to share information and ideas, I used 5/16 o.d. brass for the inserts and threaded one end 5/16-24 x.200 long and tapped the head
leaving an incomplete thread in the hole, I made the inserts extra long so I could hold them with Vice Grips to screw them tight into the incomplete thread.
I also used Lock Tite, Then I set them up in the mill to machine the 5/16 dia. to 1/4 dia., I used a boring head with the tool set to bore an O.D.
Then I turned them over and finished the valve seat and reamed the valve guide.
If this is not clear to you I will make some sketch's for you.
They say a pic. is worth a thousand words.
What machines do you have availible to you, do you have a rotory table ? I dont and I have had to make some holding fixtures, and do some makeshift machining.
Regards
Ivy McNeil
Regards
Ivy McNeil
