The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Fri May 24, 2013 9:26 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
PostPosted: Thu Sep 16, 2010 5:16 pm
Offline
I'm almost finished building two Bollaero engines. (free plans from Chris Boll) The fuel seems to made with kerosine,ether,castor oil and 3% of amyl nitrate. Is this stuff avialible in the US? Can the fuel be bought premixed?
Thanks,
Ted
Top
 Profile
PostPosted: Mon Aug 15, 2011 5:43 pm
Offline
see here : http://www3.towerhobbies.com/cgi-bin/wt ... XANCP&P=ML
Top
 Profile
PostPosted: Tue Aug 16, 2011 11:58 am
Offline
Thanks,
Ted
You can purchase any of the chemicals to brew your own diesel fuel but it is much cheaper to buy it. Besides; a DEA agent will come along with the ether to witness its use.
Top
 Profile
PostPosted: Mon Aug 29, 2011 12:21 am
Offline
Anytime I need a few oz. of Ether, I visit Auto Bone and buy the cheep starting fluid. I stuff some old window screen in a piece of large radiator hose and blast away over a catch basin. When a measurable amount is caught , I blend it into whatever.
_________________
Big Dave
Be Alert! The world needs more Lerts.
Top
 Profile
PostPosted: Sat Sep 10, 2011 8:10 pm
Offline
Big Dave,
Only problem with that, for diesel fuel you definitely do not need any of the lighter gases that are in starting fluid. One of the primary ingredients of starting fluid is propane (or butane) and by the time it boils off so has the ether - and it's diethyl ether in starting fluid anyhow which is heavier than ethyl ether. The mixture of nitro-methane and diethyl ether (along with its additives to be starting fluid) would be tough to tune a miniature diesel to since it would never be stable enough to remain the same fuel. One batch would run great and the next batch or the remains of a once good batch of fuel would be so far off that the diesel would be shelved as a failure. Ethyl ether is the only way to go for a correct and reliable mix, and even it must not be stored to too long a period of time - a few months at most. BTDT
B.Clem.
Top
 Profile
PostPosted: Sun Sep 11, 2011 8:19 am
Offline
I bend to your knowledge, I dont run model diesels.
2 cycle and lawnmower stuff, that when aged, needs a kick now and then to get running after long storage times. added to the fuel, In 10% quantity goes a long way to cutting gums and carbons with the hot burnoff. Not a staple, just a startup.
_________________
Big Dave
Top
 Profile
PostPosted: Tue Sep 13, 2011 7:35 am
Offline
Dave,
I just spoke with an old model aircraft friend who is also an 'engine head' and he says that the use of starting fluid has become the only way to get ether. He basically stated the same thing that you had, but he exchanges the spray nozzle with the nozzle on a WD40 can so that the straw can be used to control the spray into a measuring beaker for mixing the fuel. Evidently the propane or spray can propellant wasn't the problem.
So you are correct! I tried that years ago and couldn't make it work.... He did say that you need to check various brands of starting fluids, that some have a higher concentration of ether - up to 80%. He says that the industrial brands have more ether - like John Deer, and some of the marine diesel makes.....
Now I'm thinking about dusting off a shelved diesel engine and mixing up some fuel.....
Top
 Profile
PostPosted: Tue Sep 13, 2011 7:43 am
Offline
I just googled "model diesel fuel" and this came up: http://www.rcgroups.com/forums/showthread.php?t=1295580
Very similar..... (wish this had been there 35 years ago!)
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
