I have had this engine for a while. Got it at a sale and was told it was a built to run a small generator for radios in WW2. It looks as if it never had gas in the tank hence probably never run. The two spark plugs which appear to be the right age came with the engine. Please look at the pictures and possible give me more info. Thanks
Chris
Semi unknown IC Engine
Chris
www.chaski.com
Re: Semi unknown IC Engine
A fairly extensive search only found one similar.https://www.worthpoint.com/worthopedia/ ... -533452619
jack vinesThis auction is for what I think is a vintage military generator. Framework is od green. Measures 13 1/8" by 9 1/4" by 8 1/2" tall. Untested. Motor and Generator turn over.
Motor is tagged: JUDCO "46" JUDSON MFG CO. HEDGE & GILLINGHAM STA. PHILIDELPHIA,PA.
Generator is tagged: EICOR DESIGN MFG. BY EMPICO INC. CHICAGO, ILL USA TYPE: 3415-250 SER. # 1097 RPM: 5070 WINDING : GEN DUTY: CONT VOLTS : 8 AMPS : 5
Is that the same "Judson" that made superchargers?
Mr.Ron from South Mississippi
