Brand Names, Model #'s, of known Lathe, Mill, Drill 3in1
LX Kid
Re: Brand Names, Model #'s, of known Lathe, Mill, Drill 3in
Post by LX Kid » Sun May 17, 2015 6:57 pm
ken572 wrote:Hello turntwo,
Welcome to The Home Machinist Forum.
We have many great and very smart people in this forum,
that are always eager to help when and where they can.
In answer to your question about The Wholesale Tool.
3 in 1 Lathe Mill Drill Multi-Purpose Machine, Item #3014-0015
It seems to be in the family of 3 in 1's listed as follow's.
Harbor Freight's - Item/Model # HF44142
Grizzly's - Item/Model # G9729
Smithy's - Item/Model # Midas-1220LTD
Enco's - Item/Model # 328-1310
Chizhou GHF Machinery Co.,Ltd - Item/Model # CNCHQ800
Bolton Tools - Item/Model # AT750
Craftex - Item/Model # B2229
Everbest - Item/Model # EB-HQ800
QTMT - Item # 87-115-935/Model # QT25531
SUMORE - Item # SP2307/Model # SP2307
and I'm sure you will find more as you do your research.
You will find that some, (but not all parts) will possibly
be interchangable. You will be on your own when and if you do
your research etc. Some times (nowadays) if it looks like a duck
it will fool you and bark like a dog :lol: For the most part you can
make most components work with lite mod's etc.
I have been told more good then bad about Wholesale Tool.
My only complaint about them is they like alot of others don't have
manuals in .pdf format :shock: NOT GOOD FOR SALE's, downloads
are cheap and great advertizer's (HELLO) :idea: :idea: :lol:
I like my HF44142 alot.. :D With that said, with any of the 3 in 1's
made today, when it arrives at your shop, even though it is brand new :o
Go over everything and read everything that comes with it so you get
to know it well. Do proper install, (SHIMS) level, indicate, align, firmly
secure the machine in place. take off all the covers and clean it well and
relube it. Sometimes the factory leaves MFG.,dirt and grime in and on
the machine, and might also forget to lube something or not lube it
enough etc. Check and adjust all belts, check and tighten all wire
connection's. Check and tighten all nuts, bolts, screws etc. BEFORE
you power it up, manually turn anything that turns to feel for tight spots
and or loose slop etc. If found fix first, then run the machine slow to start
and run it in.
This is all the info I could find for you. (The Rest Is For You To Research) :wink:
3-in-1 R8 Multi-Purpose Machine (WT)
Order Number: 3014-0015
item/model # 3014-0015
Price $1779.00 (Seems High)
Shipping included .. unknown
Steady rest item # 3014-0020 $69.00 Extra plus shipping.
Follow rest item # 3014-0025 $59.00 Extra plus shipping.
Machine Stand shown.. Included FREE
(Looks like drip pan is attached to the stand)
Change Gears included.. YES – Which ones is unknown???
Operator Manual / Parts Book - None listed to download???
http://www.wholesaletoolcompany.com/?gclid=
CP7VoYGjl6YCFRhCgwodmT1cpA
Main Customer Service 1-800-521-3420
Email address – None offered or listed
DESCRIPTION
This multi-purpose machine is suitable for processing metal, wood
and other materials. It consists of bed, headstock, drilling and
milling units, work table, tailstock and motor. It incorporates
turning, thread cutting, drilling and milling in one machine.
Includes free stand! Uses milling X and Y power feed Drill/mill
head rotates 180 degrees Workable feed can be controlled automatically
and manually in longitudinal and cross direction. Cross direction
provides power feed for milling operation. Includes 5-inch three-jaw
chuck, 3MT and 4MT dead centers, four-way tool post, change gears,
and 1/2-inch drill chuck with R8 arbor.
BRAND ??? Maybe - (WT) :? :?
SPECIFICATIONS
Spindle Speed(s): 16 (120-3,000 RPM)
Table Size: 18-11/16" x 6-19/64"
Spindle Distance: Nose to table, 12-3/64"; center and column, 11-7/32"
Hole Through Spindle: 1-3/32"
Motor: 3/4 hp, 1 ph., 110V
Tailstock Travel: 3"
Spindle Taper: R8 (drill/mill), 4 MT (turning)
Capacity: 55/64" drill; 1-3/32" end mill; 3-1/8" milling cutter
Thread Size: Longitudinal lead screw, 6 TPI/4 mm; inch, 4-120 TPI/0.2-6 mm
Feed: 0.002-0.014"/0.05-0.35 mm
Spindle Travel: 4-21/64" (mill/drill)
Tailstock Taper: 3MT
Longitudinal Travel: 18-7/64" max.
Swing Over Bed: 16-1/2"
Distance Bet. Centers: 31-1/2"
Net Weight: 506 lbs.
Cross Slide Travel: 7-7/8" max
Ken. :)
Yours appears to be just like my Grizzly G9729 with the exception of the R8 spindle and mine is MT3.
Castaway
Re: Brand Names, Model #'s, of known Lathe, Mill, Drill 3in1
Post by Castaway » Mon Jul 31, 2017 11:30 am
Hello guys,
I just stopped by to tell you something about the CX 16 on Page two. its in turning mode in the Picture.
It's a Chinese Clone of a German, yeah, kind of gunsmith, Scale builder and fine mechanics mill.
The original is the GOLmatic MD23/24 by Gottfried Prechtl, a gunsmith from Germany.
It is considered to be one of the very few, if not the only, benchtop mill with a reasonable capability. I is also very versatile, vertical milling ("main function"), horizontal milling, turning and drilling, also it has to be rearanged every time you want to turn or mill horizontally.
Its precision is DIN certified, but it comes with a minus point for shure: The pricetag!
As far as i know, the MD23 costs around 10000€ and the MD24 witch has accessories for turning and horizontal milling in the package costs over 15000€.
Many people think they are well worth the price and they are willing to wait many month to years from order to delivery. Its not a hobby mill, its a professional piece of tool.
And a link, unfortunately only in german i think, if its allowed:
http://www.golmatic.eu/werkzeugmaschinen-cat283.html
MfG,
Ellard
