ER Collet Chuck suggestions for me!
Have a Grizzly G9729, 12x36 3-In-One and would like some opinions for a ER Collet system for my MT3 mill spindle. Just trying to get tooled up for future projects that I might want to do. Micro-Mark has a ER-25 Kit (MT3) for $118. Would another ER system be more appropriate for my mill/drill? Don't know much about differences of ER chucks and don't want to spend the money twice for "wish I had got the other one!" LoL
Re: ER Collet Chuck suggestions for me!
Kid,
I bought just such a deal, I can't remember from who, but I have systematically bought
adapters for R8, MT2, MT3, 1-1/8"-8 (myford nose) and I could not be happier.
They are COLLETS and grab small diameter stuff fiercely. Not like a 3 jaw, even a good
one. Cutters never slip, work never slips. Get a set, you won't regret it.
Gordon French
Roseburg, Oregon
Gordon French
Roseburg, Oregon
Are the M25 chucks for "tiny" micro lathes? Should I get something different, larger, for my larger 12x36 lathe using the mill/drill feature?97470me wrote:Kid, I bought just such a deal, I can't remember from who, but I have systematically bough adapters for R8, MT2, MT3, 1-1/8"-8 (myford nose) and I could not be happier. They are COLLETS and grab small diameter stuff fiercely. Not like a 3 jaw, even a good one. Cutters never slip, work never slips. Get a set, you won't regret it.
Gordon French
Roseburg, Oregon
- warmstrong1955
That's something you have to figure out, as it's dependent on the work you do, and the size of tooling you use, or plan on using.LX Kid wrote:
ER25 goes up to 5/8", I believe, so if that covers your needs.....go for it.
I bought an ER40 set, which goes up to 1", but when I bought the set, I knew that I wanted to be able to use it in the tailstock with a 7/8" end mill...something I still do often. (My lathe is a 13x40) I also bought a R8 holder, and can use the same collets in my knee mill.
Like Gordon said....very handy, and a lot more grip than a 3 jaw chuck of any kind.
If ER25 only goes up to 5/8" I would think that would be too small for general future work. I have no plans or use, at the moment, but seems I would like something that would handle at least 3/4" should I need. This is where I don't want to spend the money twice when I should have bought something that handles larger.warmstrong1955 wrote:That's something you have to figure out, as it's dependent on the work you do, and the size of tooling you use, or plan on using.LX Kid wrote:
- warmstrong1955
So....you need to do a little lookin'.
ER32's go up to 3/4", ER40's to 1".
You need to look at the size of the holder, to be sure it's not going to cause you problems, mainly....the OD of the nut.
I think I'll wait awhile before buying ER-32's because more than likely I'll use my stand alone mill/drill that uses R8 tooling. Don't know if I'll like using the milling/drilling function of the 3-In-One. I'm still considering just removing the mill/drill portion off so I can just use the lathe as a stand alone and not have the upper in the way. In it's present location I don't have the room to swing the mill/drill back towards the wall.
- warmstrong1955
You can do like many of us, and get two chucks. I bought my ER40 set that came with an MT3 chuck, and picked up a R8 chuck on fleaBay for about 25 bucks.LX Kid wrote:I think I'll wait awhile before buying ER-32's because more than likely I'll use my stand alone mill/drill that uses R8 tooling. Don't know if I'll like using the milling/drilling function of the 3-In-One. I'm still considering just removing the mill/drill portion off so I can just use the lathe as a stand alone and not have the upper in the way. In it's present location I don't have the room to swing the mill/drill back towards the wall.
There are ER-40 collet chucks that mount to a backplate, so you can get the advantage of passing stock thru the spindle. If you use an MT3 shank chuck, you will lose that ability.
