Issues with DRO on Midas 1220 LTD
warmstrong1955
Re: Issues with DRO on Midas 1220 LTD
Post by warmstrong1955 » Fri Mar 10, 2017 1:07 pm
Oh....whoops....I thought the question was to me.....
Never mind.....
Torch
Post by Torch » Fri Mar 10, 2017 1:48 pm
heavyg603 wrote:Do you ever have issues with coolant or chips on yours in the front ?
No, it's been fine. Mind you, I am using a glass scale with a double lip seal mounted so the read head on the underside. Pretty hard for anything to get at it.
The other advantage about having the scale on the chuck side is it allowed me to do this on the tailstock side:
heavyg603
Post by heavyg603 » Fri Mar 10, 2017 2:22 pm
Ah ok. Mine is a cheap magnetic one, with a questionable reader mount.
heavyg603
Post by heavyg603 » Sun Mar 12, 2017 8:32 pm
Ok what a weekend.
Broke the whole y axis down,
cleaned it,
redid a bracket that was a little sloppy on a hole,
wrecked the bracket it test (much yelling ensued),
built a new one,
remounted with lock tight
Put a new shield over the whole thing.
Really wanted to mount it on the tail stock side but I couldn't imagine a spot I could put the stand offs without some serious bracket building. I might do it in the future now that everything is working now.
Much thanks to everyone who helped! Gave me a ton of ideas on how to fix this.
warmstrong1955
Post by warmstrong1955 » Sun Mar 12, 2017 8:43 pm
Hey....if it works....you're good to go!
I bought my scales & DRO and all, and finally found a spare day to get it all installed....about 3 or 4 months later. :D
It sure won't hurt to ponder on a different installation if you choose to do that later! Nothing like having a plan!
heavyg603
Post by heavyg603 » Sun Mar 12, 2017 8:52 pm
Just added some pics. Oh I definitely want to do more here. Stumbled across the TouchDRO project, I just have to figure out how to get that on my system lol.
warmstrong1955 wrote:Hey....if it works....you're good to go!
heavyg603
Post by heavyg603 » Tue Mar 28, 2017 7:28 pm
Just did a little more with my setup. Added a Touch DRO system (http://www.yuriystoys.com/). Went through a huge hassle with interference from the scales (next time I'm buying glass) but now thats its resolved I have a ton more functionality on my existing scales.
Magicniner
Post by Magicniner » Wed Mar 29, 2017 9:05 am
I built a parallel motion slide with ball slides on parallel shafts and mounted the scale to the shaft end brackets and the read head to the slides, that gives you a stand-alone unit that is very robust and not easily damaged. The whole thing hangs outboard on the back of the lathe with a straight rod to transmit motion.
http://www.magic9designltd.com/fitting- ... uper-7-dro
- Nick
heavyg603
Post by heavyg603 » Wed Mar 29, 2017 9:17 am
Magicniner wrote:I built a parallel motion slide with ball slides on parallel shafts and mounted the scale to the shaft end brackets and the read head to the slides, that gives you a stand-alone unit that is very robust and not easily damaged. The whole thing hangs outboard on the back of the lathe with a straight rod to transmit motion.
- Nick
Well that certainly gets it out of the way. I may look at that on my next iteration of this.
