The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Sun May 19, 2013 12:13 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Hello, new owner. G9729
PostPosted: Sun Sep 27, 2009 10:54 am
Offline
Hi. Wanted to introduce myself and like so many others, throw out a question.
I have some small machining experience and I just bought the aforementioned tool.
I am currently searching for "bring home" cleaning procedures and finding bits and pieces.
Is there a comprehensive thread to show at least the minimum of what I have to do to have this machine well lubricated, up and running?
I am going to use a discount store citrus/degreaser on the ways and slides, and lube with air tool oil.
30w oil for the gearbox, kinda not sure for the external gears though...
What other places am I missing?
Thanks, ... sorry my post is long.
Good machining to all.
Jabber
Top
 Profile
PostPosted: Sun Sep 27, 2009 2:39 pm
Offline
My personal choice would be either Stoddard solvent, or mineral spirits. That way you won't introduce water to areas where it may not evaporate readily. Not suggesting your idea won't work, it likely will.
Regards air tool oil, that's not a good choice for sliding surfaces. There are oils formulated expressly for such surfaces, which provide the ability to stay in place, and to reduce, or even eliminate, slip-slide issues. Air tool oil may not serve well
A familiar name in way oil is Mobil's Vactra, typically #2. Should you make the decision to buy that particular product, insure that what you buy is intended for sliding machine surfaces. Mobil, some time ago, changed the formulation for what was Vactra, for the printing trade. It is not as well suited for way surfaces as the product that they introduced in it's place, intended for use on machine tools. Sorry, I do not know the name of the new product, but it should be available from many sources, especially machine tool supply stores. They may even call it Vactra, thus the confusion.
There are preparations in spray cans that work wonders on open gears. They are a mixture of solvents and lubricants, so they are water thin when dispensed, but quickly evaporate, leaving a thin film of very sticky grease that doesn't sling. I have a can of Keystone 423 Open Gear Grease, but I have been lead to believe that they discontinued that particular formulation. Others are available, however, so a search for open gear lubricants should yield a viable solution.
Hope some of this helps.
Welcome to the forum!
Top
 Profile
 Post subject:
PostPosted: Sun Sep 27, 2009 7:08 pm
Offline
FWIW, if you decide to go with Mobil Vactra way oil, Enco usually has it on sale for 14.95/gal, either #2 or #4
Top
 Profile
 Post subject:
PostPosted: Mon Sep 28, 2009 6:11 am
Offline
Thanks Harold_V and gunboatbay...
I just started early this morning wiping off the gunk with paper towels, haven't got to the cleaners yet.
Your advice is appreciated.
Top
 Profile
 Post subject:
PostPosted: Tue Oct 27, 2009 12:00 pm
Offline
WD-40 and ATF are my personal favorites for cleaning.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Majestic-12 [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
