ID number: 3876 - Phila 44 2700 rpm 250 watts 115 volts. Direct current power. I believe it was used in WWII to power field operations for the US Army. The Briggs and Stratton Model I engine starts and runs very well for an engine that is 65 years old. It appears to have the original olive drab green paint from the factory. It has a very nice "twist-on" oil dipstick and gas tank that has the shut off valve on top.
[links removed due to spyware scan warnings]
removed, (cleared)
Re: Briggs
I'm not sure what your post is about. Are you offering this for sale, or just showing it off? Also, you might want to post this in a more suitable forum like General Discussions or Junk Drawer. the 3-in-1 Metalworking Machines refers to combination mill-drill-lathe equipment which has a rather narrow following.
