Hey Guy's,
Has anyone seen, purchased, and or used a (Enco 328-1310) and if so, what are your
thought's and findings on this machine. I would like to see a copy of the manuals
that come with it, so I can do a better comparison to my HF 44142. I Did a visual compare
to the HF 44142 with side by side photo's and it look's to me that the only difference on the
outside is the color. I think this could end up being a good source of crossover parts etc.
Thanks.
Ken.
Enco 328-1310 Lathe, Drill, Mill, 3 in 1 multi-purpose mach.
One must remember.
Ken.
Ken.
Re: Enco 328-1310 Lathe, Drill, Mill, 3 in 1 multi-purpose m
I just bought an Enco 328-1308 and I found that it's virtually the same machine as a Grizzly other than a few oil points and the on off switch - and the Grizzly manual was WAY better than the Enco manual - just an idea - maybe Grizzly has one like the one you have too - with a better manual
Jamie
Check out my CNC (and more) projects at http://www.backyardworkshop.com
