This is my first, and probably last, time to ever teach you anything remotely related to machine equipment!Harold_V wrote:So then, if you wish to mount the face plate, an adapter is placed between the plate (that forms the spindle end) and the face plate? Makes me wonder why they wouldn't make the plate the same size for all accessories, so no adapter is needed.
No adapter is needed to mount the face plate -- that bolts right up to the spindle just like the supplied 3-jaw. The adapter is only needed to mount different sized plain-back chucks (such as the 4-jaw pictured).
And looking back at the OP's original question: Yes -- maybe. This drawing is from the manual for my HQ800V -- made by the same factory as the Grizzly and BusyBee machines for certain, and probably many of the others as well.
It looks to me like a 3-pin cam-lock chuck spindle was at least contemplated at one time. I don't know if they are still available or if they ever were produced. I don't know for sure that they make the Smithy machines and even if they do, that the spindle size for the OP's machine is the same as mine. I cross-referenced the bearing part number for the above diagram and the dimensions are the same as the spindle in the Grizzly 9729, which seems to be the base model version of my machine, and I know that they have an R8 mill spindle that is a drop-in replacement for the standard MT3 mill spindle because I had to swap it myself when they mistakenly shipped the machine with the wrong one.
The factory where these things are made is the Anhui Chizhou Household Machine Tool Co., Ltd. Their website is http://www.czjyjc.com/en/index.asp. Warning: Dealing with them can be an exercise in frustration because a) English is not their strong suit and b) They tend to cut off the conversation abruptly for no apparent reason. The 12 hour time difference doesn't help either.
