That's a CQ9109 made by Shandong Linyi Jinxing Machine Tool Co., Ltd.
Here's the specs off their website:
Turning dia. (Steel) 40mm
Swing dia. over bed 360mm
Distance between centers 300mm
Spindle bore 20mm
Turning speed / grade 200-1800r/min/9
Longitudinal stroke 210mm
Lateral stroke 180mm
Longitudinal feed 0.0660.226mm/r
Cross feed 0.0370.127mm/r
Metric pitch/grade 13/9mm
Inch pitch/grade (optional) 724/12 T.P.I
Max.Drilling dia. 16mm
Max.disk milling dia. 63mm
Max.vertical milling dia. 12mm
Table size 200×185
Drilling and milling spindle speed / grade 430-2000r/min/5
Stroke of drilling and milling spindle 75mm
Power of motor 0.370.554kw
N.W. / G.W. 180/260kg
Overall dimensionL×W×H 910×790×810mm
Case dimension (L×W×H 1150×745×910mm
So yeah, the distance between centers is 12", but you can only move the table a little over 6"! Which half of the piece did you want to work on?
Northern Tool and Equipment in the US seems to carry that thing's little brother (CQ9107, no gears or power feed at all!) so maybe they can get that one too. Another option is to contact the factory and ask them if they have a US distributor for that model.
Personally, I look at that and understand how 3-in-1 machines got a bad reputation, but hey, it might be useful for some small stuff -- provided you don't need to thread your piece more than half way.
