milling table advice
mikeamick
Post by mikeamick » Sun Dec 11, 2011 5:32 pm
as is commonly the case my compond is way lower than my mill. my question is .. do I
get a small milling table .. then add a vice like the one laying there ...
or ..
do I get a really big ass vice and just bold it to the compond.
Torch
Re: milling table advice
Post by Torch » Sun Dec 11, 2011 6:48 pm
Yes.
You can get a riser block that lifts the vice, 4" or 5". What I did was to buy a tilt table which does dual duty but has to be carefully leveled after using it on an angle.
For a quick job you can take light cuts with the quill extended, but it's not as rigid. And of course, for larger objects (at least 3" tall) you simply omit the riser block.
It would be nice if these things could lower the column another 3" or 4".
mikeamick
Post by mikeamick » Sun Dec 11, 2011 7:54 pm
ok .. thanks tourch
mac.doogle
Post by mac.doogle » Fri Jan 13, 2012 10:55 pm
What model is the 3 in 1? I have never seen one like that. I know it's off topic but I'm curious.
Everyone want's a job until they get one.
