DRO for 3-in-1
mikeamick
DRO for 3-in-1
Post by mikeamick » Mon Mar 19, 2012 2:30 pm
If you were ordering a DRO for our machines .. would you order the
lathe display .. or the mill display .. ??
Morph
Re: DRO for 3-in-1
Post by Morph » Mon Mar 19, 2012 6:30 pm
mikeamick,
Dros Pros has a universal display for either mill or lathe. You can switch between the two with a push of a button.
Torch
Re: DRO for 3-in-1
Post by Torch » Mon Mar 19, 2012 6:41 pm
Mill -- with 3 axis. (At least. You could add 2 more if you wanted something on the tailstock and the column, but I think that's overkill.)
Lathe DROs usually only have 2 axis. The 3 axis DRO works very nicely for both milling and lathe operations. You just have to forget about the conventional X, Y, and Z nomenclature because your spinning axis changes depending which way you are using the machine.
Personally, I connected the carriage bed to the X axis, the cross-slide to the Y axis and the mill spindle to the Z axis. So no matter what I'm doing left/right is X, fore and aft is Y and up/down is Z. Negative is to the left, away from me and down, respectively. It make sense when using the lathe, since facing operations make things shorter and the tool post is on my side of the spindle when I'm turning. Similarly, milling reduces the dimensions as the tool gets lower.
But that's just my 2¢. Your opinion may differ.
Oh, one other thing: when I'm milling I set the Y axis for direct reading ("radius" in my DRO's nomenclature). When turning I set the Y axis to show the diameter of the part, which means the display changes 2 units for each unit of actual movement. A very handy feature! Some lathe handwheels are marked like that too.
Edit: I see Morph jumped in there just ahead of me. I bet the R or D feature is what he is talking about. On mine it's slightly more than 1 button: cycle power, press enter during reboot, down arrow 3 times, enter, Y, enter, up arrow 3 times, enter.
mikeamick
Re: DRO for 3-in-1
Post by mikeamick » Mon Mar 19, 2012 10:28 pm
I'll check them out morph .. thanks
and torch .. I didnt know you could do that ... absolute position I knew ..
but .. current dia of the part ! ?? Thats hot ..
BTW where did you get that cent symbol .. when talking about 2cents .. smart phone ?
Re: DRO for 3-in-1
Post by Harold_V » Tue Mar 20, 2012 12:53 am
mikeamick wrote:BTW where did you get that cent symbol .. when talking about 2cents .. smart phone ?
Alt 155 ¢
Alt 248 ° (degrees of angle or temperature)
Torch
Re: DRO for 3-in-1
Post by Torch » Tue Mar 20, 2012 5:25 am
Harold_V wrote: Alt 155 ¢
Has to be on the numeric keypad though -- won't work on the main keyboard.
These also work:
Alt 0162 ¢
Alt 0176 °
3 character codes are the ASCII character set, 4 character codes are the Unicode character set.
If you don't have a numpad (eg: many laptops) but are running windows you can click "Start" then "Run" then type "charmap.exe" and cut-and-paste the character.
Torch
Re: DRO for 3-in-1
Post by Torch » Tue Mar 20, 2012 5:55 am
Oh yeah, forgot to mention: on mine, the R or D feature can be enabled on any axis. Sometimes handy when milling using a rotary table.
