The Home Machinist!
It is currently Wed May 22, 2013 3:12 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: EMCO T-nuts
PostPosted: Wed Jun 13, 2012 11:46 am
Offline
The T-nuts that fit the cross-slide on the V10 appear to be an odd size. I've got three of the originals, but haven't been able to locate a source for more. The slot is nominally 10mm (measures more like 10.7).
I have some 3/8" size, the nearest SAE measurement, but those don't fit; and the nearest metric ones I've found (Busy Bee 8mm) still are too big to fit in (although the slot-width would work, the "crossbar" of the T is too wide).
Has anyone got a source for the correct ones ?
I certainly could make some, but I'm lazy.
Thanks...
_________________
Pete in NJ
Top
 Profile
 Post subject: Re: EMCO T-nuts
PostPosted: Wed Jun 13, 2012 1:18 pm
Offline
Buy the 8mm and just mill the sides?
Top
 Profile
PostPosted: Wed Jun 13, 2012 1:32 pm
Offline
Thought of that, but the part that comes up through the slot is also a bit narrower than the original. Dimensions are downstairs, but IIRC, it would have about .060" clearance. I'm not sure that matters, as long as the "crossbar" fits.
Milling them off would likely be a bit of work, too -- I think they're hardened. Surface grinder (which I don't have - yet!) would be better, I think.
Thanks...
_________________
Pete in NJ
Top
 Profile
PostPosted: Wed Jun 13, 2012 3:33 pm
Offline
Can't say about the 8mm, but the 3/8" ones from BusyBee weren't hardened. I had no trouble adjusting their size -- which was a good thing, since the dimensions from nut to nut were a variable. I even got some that weren't tapped in the centre of the T!
Top
 Profile
PostPosted: Wed Jun 13, 2012 6:19 pm
Offline
Hmmm... maybe it WOULD be better to make my own !!!
_________________
Pete in NJ
Top
 Profile
PostPosted: Wed Jun 13, 2012 6:39 pm
Offline
I'm pretty sure you would take better care in measuring things than the apprentice in the Chinese sweatshop did.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
