ANYONE NEED BOILER CHECK VALVES
- Trainman4602
I am taking orders for Hancock Boiler check valves.
I will be making about 30 valves.
I will supply them with either a spanner nut or a flange connection. I will also offer the option to have a curved connection.
The prices are as follows.
HANCOCK BOILER CHECK 1 ½ scale.
With flanges as pictured ------------------- $200.00
With flanges and curved inlet-------------- $250.00
With spanner nuts-------------------------- $195.00
With spanner nuts and curved inlet--------$230.00
They will include a boiler fitting with either a 1/8 or 1/4 NTP thread and a spare set of “O” ring seals
All will have a 5/16 tubing solder furrel connection.
I will ship Free ( no handling fee ) to anywhere in the USA (lower 48).
Foreign shipments extra.
PM me if you are interested Thanks dave
Re: ANYONE NEED BOILER CHECK VALVES
What type of valve and seat are these? Are they ball checks or like the Superscale style?
- Trainman4602
There is no ball
Actually they have a MERCER style seat. I use an "O" ring seat. I get a more positive by using a Viton "O" ring . The metal to metal seal eventually leak with the build up of scale.
I will post a picture when I get to the shop.
Hi Dave, you still making boiler checks?
Same question here. I would like the spanner nut + curved inlet assembly.
I would like to get two curved and two straight with the spanner nuts if have you have them too Dave.
- Trainman4602
Working on safety valves check valves will be next
Dave,
Put me down for two Flanged Boiler Check Valves, 1/8" NPT and straight tail piece.
Thanks,
Frank Webb, PLS
Thanks,
Frank Webb, PLS
Dave, can these valves be mounted horizontally ? Or must they always be vertical ?
Jerry
Jerry
www.chaski.com
- Trainman4602
Hi Jerry
I'm not sure as this is a new product. I will test every valve and I will preform a horizontal test as well. I'm doing a run of safety valves and should finish by the end of the week Check valves are next.
Thanks, Dave. Your tests will determine whether or not I need the curved tail piece. i will need two check valves, flanged, 1/8" pipe when you are ready with them.
Jerry
Jerry
www.chaski.com
Dave:
Good to see the demand for your products!
Thanks for your work.
