For sale, Boiler and hand pump setup.
Boiler is 6" in dia. 24" tall from base, and base is 12 by 18". It is stamped for 100 psi. See pictures.
Would be good for testing stuff, injectors, check valves, safeties etc. or running stationary engines?
I have had it for years and never did anything with it other than paint the top (smoke box).
Asking $550.00 plus shipping, from 63051. It is probably around 60 Lbs
Pm me if interested
Thanks Tim
Re: Boiler and hand pump
Good morning,
I'm interested in this boiler and local (St. Peters). Would like to talk to you and come by to take a look at it. Do you know is it home built? doesn't appear to be.
Thanks,
Eric
636 541-3040
Thanks,
Eric
636 541-3040
Can you tell if it is copper or steel and assuming it is coal fired, does it have the grates?
If not coal fired, how?
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
Hi Charlie,
It's all steel, I forgot to mention that it has propane burner in it. You could change it over to coal if you wanted.
Thanks Tim
Thanks Tim
Can deliver to Mid South Live Steamers spring meet.
PM me if interested
PM me if interested
