I have two 3/4 scale Little Engines Northerns and a tender for sale both Northerns run on air and have boilers. One boiler in mounted and jacketed. I have leak checked the boilers to 120psi no leaks. Both engines are all cast iron and brass no aluminum. The tender is all copper with a cast brass base. Six wheel trucks. It is complete and ready to go not painted. The northern with the boiler mounted 2200.00. The Northern on air with Boiler 1500.00 the tender 1100.00. I also have a complete cast casting set for a 3/4 centipede tender the main casting and all the axle boxes are brass. 500.00 please email for photos. Can't figure out how to post them.
Trainsplanesandautos@gmail.com
Mark
3/4 scale equipment
Re: 3/4 scale equipment
You post pictures with the browse button on the page. If you reply and hit the Full Editor button you will see it.
You should post your location, because a train 25 miles from me is worth a lot more to me than one across the country.
You can set that in your profile, then it shows up every time you post.
The Locomotives are located in Fort Worth Texas.
Are the engines 3/4 scale, or 3/4" =12" scale? They are not one and the same, although I suspect what you mean is the 3/4" =12" scale.
- backyardrails
Mark
I pm'd you
Bernie
I pm'd you
Bernie
All sold
