MAKE YOUR OWN SAFETY VALVES
- Trainman4602
If you’re brave enough to make the attempt to build your own safety valve here is the opportunity.
I have a number of these castings the hex base is machined and the body is as well. The casting on the left is a muffler casting. Missing are the valve seat, spring, spindle, blow down ring and boiler fitting. I have no prints. That is up to you. I posted a picture of a cut a way view of a full size safety with a muffler so you can get the idea on how it works.
When I purchased some of the LS MFG line these came with them. I already had the Mercer valve so there was no need to duplicate it. I had visions of finishing them for sale but there is only so much a person can do.
I have around 50 sets. The price for the set is $50.00 plus $6.80 shipping
PM me if interested
PM me if interested
Re: MAKE YOUR OWN SAFETY VALVES
Dave please tell us about the lower photo of the prototype "Pop" Safety Valve. cut-away Model. What model is it, who has it, do you have the prototype drawings, etc... Thanks!
Morning Dave, is the set a casting to make a pair for 50 bucks?
- Trainman4602
No it is $50.00 per set as shown. I you buy 2 sets I can save you the shipping $6.80 or two sets shipping
I don't know what make valve it is. The picture was taken at the Pennsylvania State Railroad Museum.
The valve that Dave has is a Coale Safety valve. They were available in sizes that I am aware of from 2½ to 4 inches.
You can check out the following patent numbers 459268, 855431, 825380, 488309, 461237, 297066, 96999, 657086,
338827.
There are also decent drawings in the 1930 & 1941 Loco Cyclopedias
Mark Landgraf
Albany NY
338827.
Mark Landgraf
Albany NY
PM sent. I hope that you still have some of these.
Andy Pullen
Andy Pullen
PM sent, hope that you have 2 sets left
Ken Roeh
Ken Roeh
- Dick_Morris
I have several items on prototype Coale valves including complete prototype drawings for a 3" version as was used in locomotives on the Tasmanian RR that I can share. I was able to use them to reproduce a couple of internal parts for our full sized valves on ARR 557.
What would you need to copy them? I would like a set.Dick_Morris wrote:I have several items on prototype Coale valves including complete prototype drawings for a 3" version as was used in locomotives on the Tasmanian RR that I can share. I was able to use them to reproduce a couple of internal parts for our full sized valves on ARR 557.
Thanks!
Andy Pullen
- Dick_Morris
Andy (or anyone else) send me your email. I will also send the drawings for a 2" valve and the maintenance/overhaul instructions for Coale valves from several railroads.
Lots of good info if you ask for it --
Thank you!
Thank you!
Great info! More parts in them than I thought.
Thanks!
Andy Pullen
Thanks!
Andy Pullen
