[I am making another run of safety valves. If you want them please pm me I’ll place you on the list to receive them when they are finished some time in April.
I can set them from 95# to 145#
The price for the 95# to 130# will be $175.00 ea.
I’m getting a little more for setting them at a higher pressure. For the 135# to 145# they will be $200.00 ea.
The higher pressure are a little bit harder to set and it takes a little longer to do.
They have a 1/8 NTP pipe thread end. If you need a larger thread size I sell a stainless steel reducer bushing in 1/4, 3/8 and 1/2 in sizes for additional $5.00.
These valves are very reliable and will relieve the pressure adequately.
Here is a video on them and how they work. Please watch the entire video.
https://www.youtube.com/watch?v=98zLb4BJeOI&t=15s
TAKING SAFETY VALVE ORDERS
- Trainman4602
Re: TAKING SAFETY VALVE ORDERS
PM sent
- Trainman4602
I did not get the PM
Hello,
I haven't got a response to my message about these. Can you confirm you have received it?
- Trainman4602
Hi
I did respond to you via PM check your PM.
You are on the list I believe I asked the question as to what Pressure you waned them set to?
Well, still no PM's in my inbox about it. Maybe there's something wrong with the forum.
My message identified two safeties, one at 125psi, and the other at 130psi, plus two of the reducer bushings, 1/4" to 1/8" NPT
- Trainman4602
I have your order don't worry
