I picked this project up with intentions of completing in the future but have to many other things that need my focus so it must go...
This is a gas powered Davenport that has a belt driven transmission (forward and reverse). There is a new 6.5 HP engine installed and 2 handles, one for engaging the belt and one for forward, neutral and reverse selection. The output shaft from the transmission has a chain drive to one axle and the axles are connected via visible eccentrics and side rods. The frame is comprised of steel and aluminum stock with removable pedestal binders for each axle and wood front and rear bumpers. The body is steel bracing with aluminum panels that are removable for accessing the engine/drive bays. Both left and right sides have hinged panels in the front that allows quick access to the transmission and chain drive components. This project was assembled but never tested or run by the original builder. I have started the engine and ran it on a test stand and noticed the side rods have an adjustable eccentrics that will need adjustment/rework as there seemed to be some binding as the wheels rotate. Overall it has the capability of being a fun little runner and a great beginner project. It is available in the Cleveland , Ohio area. It is available for local pickup but could be crated and shipped at buyers expense.
7.5 gauge Davenport project - $1300 ****SOLD****
Re: 7.5 gauge Davenport project - $1300
PRICE REDUCED TO $1150 ... Need the space! I also may be able to assist with delivery as I will be traveling from Ohio to southern states to Florida
Good afternoon. I'm interested but have a couple of questions: (1) what scale is it? (2) what is approx weight? (3) what would you charge to crate it?
Please use PM for reply. Thanks
When are you coming to FL and where ? I'm in Zephyrhills.
0-4-0
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
44 cars rolling stock
2400' 7 1/2" track
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
2400' 7 1/2" track
