One 0-4-0 KIT LEFT***SOLD***
- Trainman4602
Hi all
I only have one kit left
The response as been great. great enough that i will be finishing the casting set and the other things like spring sets and cab and tender laser cuts.
Re: One 0-4-0 KIT LEFT
Dave: That's terrific! One can never have too many Reading A5a Camelbacks, nor K4s Pacifics. I hope the enthusiasm of we owners helped introduce the project to others. Are you, by chance, keeping one for yourself, or are you already stockpiled with steamers?
- Trainman4602
I kept back two sets to build up. One will be 7 1/4 camelback and one will be 7 1/2 rear cab version. I also want to build two heavy 1900 version Americans so I have enough parts for them with the exception of the drivers I have a pattern for the wheel but need to get them cast.
- Trainman4602
Re: One 0-4-0 KIT LEFT***SOLD***
The last kit is sold.,
I may run it again if I could get at least 6 customers to make it worth doing. I could start a list.
I have to laugh - as if you don't have enough steam loco projects underway! When you assemble your Reading A5a CAmel, I hope you post pictures of the detailing. So with the K4s, 1361, these two 0-4-0 switchers, a pair of 4-4-0's, where does that put the CNJ "Mike" in terms of rolling out?
- Trainman4602
I have no steam locomotives being built in my shop at the moment. Just working on safety valves and injectors starter valves and other Mercer products.
- Trainman4602
I should have mentioned I plan on using the same cylinders and valve gear for the 4-4-0 so I'll do them all at the same time. For the 4-4-0s it is just a matter of the frames lead truck (which I already have) and boiler same tender trucks with slightly different tender.
- BlackStack
Are you planning a similar 4-4-0 casting kit in the future? I'm sorry if I missed the announcement elsewhere.Trainman4602 wrote:I should have mentioned I plan on using the same cylinders and valve gear for the 4-4-0 so I'll do them all at the same time. For the 4-4-0s it is just a matter of the frames lead truck (which I already have) and boiler same tender trucks with slightly different tender.
BlackStack -- Just blowin' smoke.
- Trainman4602
I'm Not sure on that I might I'll have to build it first and see the performance.
