To compliment my line of 1.5" scale Nathan DV series mechanical lubricators I'm now offering Detroit High Pressure Terminal Checks. These little fellas are found all over late steam era equipment. They were used to ensure one way flow of pressurised lubrication to valves, glands, shafts, flexible steam joints, pivots and bearings. These are dummy units although they could be through-drilled for actual oil lines.
US13.50 or AU$18.00 ea
1.5" Detroit Terminal Check Valves - New from Dans Details
I just don't understand pronouncing solder as "sodder"... where did the L go?
Re: 1.5" Detroit Terminal Check Valves - New from Dans Details
same place the salmon went
Bill, best answer I've heard yet!
is that a working lubricator?
steamjunky wrote:is that a working lubricator?
HThese are dummy units although they could be through-drilled for actual oil lines.
