TAKING ORDERS FOR SAFETY AND STARTER VALVES
- Trainman4602
I am setting up to make runs of safety and Starter valves, for delivery in early spring.
I only make 40 of each at a time so if you need either type please send your request.
The Safeties can be set to pressures from 95# to 140#. If ordering two valves they should have a difference of 5# each.
PM me if interested Thanks Dave
- Trainman4602
Re: TAKING ORDERS FOR SAFETY AND STARTER VALVES
I have a few safety valves in stock but need to be set. Is there anyone that would like to place an order?
PM sent
Northwind
Northwind
- Trainman4602
I have one set of safety valve left from this run set to 120 and 125. These are the last for a while. My test boiler blow a tube and I use the K4 to set them not easy when using a coal fired boiler.
I will be re tubing the test boiler soon.
- Trainman4602
ALL SOLD
Any idea when the next run will be? Im going to need safeties for my shay in the next couple months but never received a PM or an email from you that this batch was ready. I dont check this section of the board much so I haven't found out till now
-Tristan
Projects
Projects
- Trainman4602
Sorry Tristan
I had a problem with the test boiler it blew a tube. I have 30 valves assembled and ready to test. I will be fixing the boiler soon. I have quite a few customers needing safety valves. Looks like the Mercer safety is catching on.
What pressures do you want 120 125?
125 and 130. Hope that tube isnt too much of a pain for you
And Id say theyre catching on! They nice looking and work well. Every pair I've seen snaps open and closed perfectly every time
-Tristan
Projects
Projects
- Trainman4602
Tristan check your pm I have valves for you
