Up for sale is a pair of cylinders castings for a 1½” steam engine. The material is cast Iron. The cylinders are currently bored and faced to the dimensions listed below. The mating faces have been machined and the bolt holes have been spot-faced. Additional machining will be required to make these cylinders operational.
Valve liners and drawings are not included in this sale.
Cylinder Specs:
Design: Two piece (split) with piston valves
Overall dimensions (both halves): 16” width x 6¼” length x 8” tall
Total weight (both halves): 73 lbs
Piston bore / length: 2.94” x 5.00” (Faced to 4.00”)
Piston distance (center to center): 11.19”
Piston valve bore / length: 2.00” x 6.19” (Faced to 2.88”)
Piston valve distance (center to center): 12.94”
Vertical height from Piston to Piston Valve: 3.50”
Frame opening cutout: 5.75” width x 5.00” length x 1.25” tall
Distance from frame opening to center of Piston (vertical): ~¾”
Smokebox diameter: 9¾” to 10½”
Asking $1,000 but willing to negotiate. Shipping is not included due to the weight. Item is located in Milwaukee, WI.
If additional information or pictures are needed, please feel free to ask. PM are also acceptable for communication.
1½" Scale Cylinders - Piston Valve ****SOLD****
- SPSteam2491
- SPSteam2491
- SPSteam2491
Re: 1½" Scale Cylinders - Piston Valve
Price reduced to $800. Shipping is now included free to the continental 48 states. Outside of that range may require some additional shipping charges.
Thanks
John LaFavor
Pacific Design Shops
John LaFavor
What casting set were these from?
- SPSteam2491
To be honest, I am still trying to determine that. My grandfather (Don Denzin) acquired these cylinders (either through purchase or had them cast at a local foundry) at least over 20 years ago. I believe his plan was to convert his 1½" scale little engines Atlantic from slide valves to piston valves but never got around to it. I now own that engine and have no complaints of the slide valves so I am going to stick with those. I also have 5 steam engine projects that are in various states of completion from his collection and hundreds of parts so I am trying to find good homes to the projects that I will never get around too.
I cannot find any marking on the cylinders either and have not found any manufacturer that has similar looking cylinders.
Thanks
John LaFavor
John LaFavor
- SPSteam2491
These cylinder have been sold. Thank you for looking.
Thanks
John LaFavor
John LaFavor
