Mercer starter valve o ring size?
Anyone know the size of the Mercer starting valve O ring?
- Trainman4602
Re: Mercer starter valve o ring size?
Did you think to ask me? I got your PM and I'll address it as soon as I return from Cabin Fever Expo on Monday
I text you over three weeks ago and then PM ed you. Neither were answered. How am I supposed to know your at an event. You posted on Tuesday about your safeties and starters. I PM you Wednesday.
I'm not mad about it Dave I'm just looking to get some pieces. Hope you enjoy steaming this weekend.
Thank you
Scott
Thank you
Scott
- Trainman4602
Hi Scott
I have been busy with pattern work and so on so I will get to your order on Monday. BTW I don't have the wrench I have the other stuff I'll give you the McMaster Carr part number you can order the O rings By the hundred Cheaper then they would be from me. I have the nuts and end pieces
Well I never heard back from Dave after phone calls and texts, pm's etc. sooooo does anyone have the McMaster Carr prt # for the mercer starter valves ?
With dimensions the O-Ring size can be found....but if you have the dimensions, you can get it yourself (obvious...)
Dave will get back with you...patience is a virtue.
Apparently will have take that route. Was just hoping for an easy step in just getting the part number.
Thank you.
Thank you.
- Trainman4602
Listen I posted on you PM LOOK at your PM PLEASE
- Trainman4602
I answered this a week Ago PLEASE LOOK AT YOUR PM
- Trainman4602
HERE IT IS IN CASE YOU DON"T KNOW HOW TO CHECK THEM
Trainman4602 wrote:Tue Jan 16, 2018 9:39 pm Hi Scott
For one set of union nut and feral will be $15.00 per set.
Shipping will be $7.15
I do not have wenches
"O" ring number McMaster Carr 9464K12
Scott
Now that you know the oring size, i.e. 007 you may be able to find it at a NAPA store or local hydraulic shop. Just make sure it is Viton.
John B.
John B.
