FOR SALE VFD (variable frequency drive) ****SOLD****
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Moderators: Harold_V, WJH, gwrdriver
Trainman4602
Post by Trainman4602 » Tue May 22, 2018 2:47 pm
Hi all
I have a VFD for sale. It is in good working condition. It will run your entire shop. It converts single phase to 3 phase. Included is an operation manual and is good from 1/2 HP to 30HP. and is 240 volts to 460volts.
$225.00 includes shipping in USA.
PM me if interested
jamesjgould
Re: FOR SALE VFD (variable frequency drive)
Post by jamesjgould » Mon May 28, 2018 2:33 pm
Just sent PM.
Jim Gould
0-4-0
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
44 cars rolling stock
2400' 7 1/2" track
Trainman4602
Post by Trainman4602 » Wed May 30, 2018 12:18 pm
Price reduction asking $160.00 includes shipping
jamesjgould
Post by jamesjgould » Thu May 31, 2018 10:21 am
Would you take $100 ? I can give you a credit card # or mail you a check.
JJ
0-4-0
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
2400' 7 1/2" track
jamesjgould
Post by jamesjgould » Thu May 31, 2018 10:34 am
Plus shipping.
JJ
0-4-0
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
2400' 7 1/2" track
Will's 2882
Post by Will's 2882 » Thu May 31, 2018 1:21 pm
Please give the full model number of this controller.
The unit will only be one or the other voltage,
Trainman4602
Re: FOR SALE VFD ****SOLD****
Post by Trainman4602 » Thu May 31, 2018 4:10 pm
The VFD has been sold
jamesjgould
Post by jamesjgould » Thu May 31, 2018 6:46 pm
Dave,
How many motors were you able to run from this at one time and did you use an idler motor to stabilize the output ?
JJ
0-4-0
4-6-0
4-4-2
4-4-0
2-6-0(2)
5 batt elec
2400' 7 1/2" track
Trainman4602
Post by Trainman4602 » Thu May 31, 2018 7:44 pm
I just used it to make my belt driven mill variable speed. I have a rotary converter that I run the shop on 10hp and I have a 25hp as well.
Post by Bill Shields » Thu May 31, 2018 8:01 pm
just as a side note...if you have never worked with these boxes and are thinking 'rotary converter replacement'....
you need to be VERY CAREFUL about running more than one motor at a time from a VFD...since you should NOT start / stop the motor by disconnecting the motor from the VFD...you start / stop the motor from the VFD control panel on / off switch.
disconnecting the line / motor from the VFD can lead to some very interesting demonstrations of 'letting the smoke out of your electronics'.
rrnut-2
Post by rrnut-2 » Fri Jun 01, 2018 8:52 am
Bill: Depends on the quality of the drive. The "cheap" drives yes. A friend of mine does this with his shop...turn on the drive when he walks in the door, then turns on the BP with the For/Rev switch. Same with the lathe. Only once was the smoke and parts let out of the VFD...direct lightning strike.
I have a couple of industrial customers that supply multiple motors off one drive. The controls are set up that at least one motor has to be running
at all times. One drive has 5 motors on it and all motors are the same horsepower and rpm. The VFD is sized for the total hp.
The drives are Toshiba, Allen Bradley and WEG. As I said, not the cheap ones.
Not that I recommend any of this, but it can be done.
Jim B
