Re-manufactured 1-1/2” Scale Searchlight Signal
Product Number: D261-1AS52
Serial Number 33
One Unit Ground Signal w/Single Instrument Case.
Nominal height 33 inches.
Searchlight employs single coil operating unit and retrofitted 2700K chromaticity LED light source for operation at 12 volts D.C.
Internal plano-convex lens explodes light source into narrow projected beam which must be aimed at approaching traffic.
Encapsulated permanent magnet rotor glides on super slick Teflon bearing.
Current fed one direction through mechanism coil causes a projected green aspect.
Reversing polarity, the unit projects a yellow aspect. Unit displays red aspect when no current flows through coil.
Light source draws about 14 milliamps. Coil resistance is approximately 171 ohms at 68 degrees F.
Four prewired signal leads (AWG 22) are random 14 inch length.
Two leads connect to the light source, and the other two leads connect to the mechanism coil.
End user must configure how they will control the device.
The signal is constructed from outstanding weather resistant molded polyurethane and aluminum
components with stainless steel mechanical fasteners.
Removable back panel on base of mast instrument case provides accessibility and features recessed neoprene gasket to keep out weather. Bottom of base has single 1/2” –NPT threaded outlet.
Non-operating instrument case door front details include door hinges, hasp, plated brass pad lock,
large type ventilators, and all the rivet heads to count.
Price: $560.00 Shipped (Contiguous U.S.A. Only)
Accept Pay Pal, Check or Money Order
Send inquiries to (atkinsonworks@gmail.com) with subject title: Searchlight
Thank You.
John D. Atkinson
You Tube Video Reference: https://www.youtube.com/watch?v=Fez-nJA ... jreload=10
Re-manufactured 1-1/2” Scale Searchlight Signal ****SOLD****
- Atkinson_Railroad
- Atkinson_Railroad
Re: Re-manufactured 1-1/2” Scale Searchlight Signal
Searchlight is Sold.
