TAKING ORDERS FOR HANCOCK CHECK VALVES
- Trainman4602
I finally got around to making up the check valve prototypes. They will be available in a few weeks. You can get them in either flanged or spanner nut styles. I will have a limited number of elbows available at an extra cost.
The valves feature a top shut off that can be utilized to clean the check valve while under steam if needed.
All the seats and gaskets are “O” rings and the hardware is stainless steel.
You can get the boiler flange fitting in a 1/8 male NTP pipe or a 1/4 NTP male boiler fitting, included with the valve.
The supply fitting is for 5/16 OD tubing solder connection.
Prices as follows
Flange fitting $225.00 each
Spanner fitting $225.00 each
90 degree Elbow $ 50.00 each
Shipping in the USA free foreign orders shipping will be extra.
PM me to get on the list
PS as this is a new product I only have about 30 body castings I will have more soon.
Prices as follows
Re: TAKING ORDERS FOR HANCOCK CHECK VALVES
Great work Dave.
Tim
Tim
Dave,
Do you know if they will function in a horizontal position?
Jerry
Jerry
www.chaski.com
- Trainman4602
Yes
Dave, Put me down for two (2) each Flange fitting check valves at $225.00 each and one (1) 90 degree flange Elbow $ 50.00 each.
Total $500.
Jerry
Total $500.
Jerry
www.chaski.com
DAVE,
Look at your PMs. You have one from me for check valves !! Plus the previous post.
Jerry
Jerry
www.chaski.com
- Trainman4602
Yes Jerry I have you on the list. working on them now.
Ill take 2 at PLS fall meet - if they they can hook up to my existing arrangement (Hudson)
- Trainman4602
I don't think they will be ready by then. Doe you want spanner nuts or flange fittings?
- Trainman4602
To Jerry_H
Hi I sent you a PM
Hi I sent you a PM
You will have to forgive lae reply as my telephone cable is out under a paved road and it will take who knows how long to replace it.
Jerry
Jerry
www.chaski.com
