After deliberating this for a while, offering up my K4 materials and drawings.
Included:
Frame assembly
Rear frame assembly
Cast iron journal box blanks
Brass journal box covers
Axle bearings.
Dan Horting Cylinder castings
2 trailing truck wheel castings
8 lead truck and tender wheel castings
Air brake cylinder castings
Lead truck frame water jet castings
Eccentric water jet blanks
2 complete sets of main driver castings, 12 wheels; 4 centers, 8 front / rear
Smoke box front
Mercer PRR handrail stanchions
Mercer PRR electrical junction box
Mercer Sunbeam headlight kit
Mercer (2) safety relief valves
Mercer (2) Starter valves
(2) CNC cut brake hangars
60 + drawings / prints. Many from PRR archives and other prominent builders. Included are the drivers, frame, trailing truck, valve gear, boiler, etc.
$1800 OBO + shipping for everything. If you are interested and would like to talk over what’s included and what work was completed to date, happy to discuss with you. If you would like this shipped, I can build a crate and ship via freight which might be the least expensive. Give me a call 443-604-0655 or email is okay also; jpeach1@gmail.com. Thanks for any interest. Jim Peach
K4 Build ****SOLD****
Re: K4 Build
I've had some questions about the drawings. It is more drawings than I had recalled. Attaching the list. Also was requested for a close up of the cylinders and rear frame assembly. The cylinders are excellent, cored design See Pictures. Thanks, Jim
PRR Large Format Drawings
PRR Trailer Truck Arrangement 1926
PRR Trailer Truck Frame 1948
PRR Trailer Truck Wheel 1926
PRR Driving Wheel Center Front And Rear 1936
PRR Main Driving Wheel Center 1935
PRR Frame 1942
PRR Trailer Truck Forged Details 1926
PRR Trailer Truck Frame 1922
PRR Trailer Truck Box 1923
PRR Frame 1927
PRR Driver Brake Arrangement 1923
PRR Valve Gear 1926
PRR Tenders Arrangement 1924
PRR Boiler Arrangement 1925
PRR Tender Trucks Arrangement 1937
PRR Front Frame Casting Corner Bracket 1944
PRR Steel Car Arrangement 1922
PRR Locomotive Elevations 1929
PRR Pilot Arrangement 1930
PRR Air Pump Steam Pipe 1931
PRR Pressed Steel Smoke Box Front & Door 1942
PRR Spring Rigging Arrangement 1936
PRR Engine Truck Arrangement 1928
PRR Detail of Fire Box 1947
PRR 27” Cylinder 1949
PRR Power Reverse Gear Auxiliary Reservoir & Piping Application 1945
PRR Boiler Fittings In Cab Arrangement 1938
PRR Main Rod With Fixed Solid Bushing At Front End Arrangement 1934
PRR Crosshead And Details 1936
PRR Engine Truck Wheel 1948
PRR Side Rods 1939
PRR Valve Stem Stuffing Box Crosshead Guide And Mechanical Lubricator Bracket
PRR Trailer Truck Wheel 1932
PRR Valve Stem Stuffing Box & Crosshead Guide 1945
PRR Locomotive Guides 1943
PRR Tenders Tank Arrangement 1927
Sierra Grande Models – Large Format Drawings
Sierra Grande Models – Cylinder Block, Smoke Box, Stack & Exhaust Stand, Steam Pipe Cover, Valve & Cylinder Liners
Sierra Grande Models – Trailer Truck Assembly & Details
Sierra Grande Models – Frame & Details 2:1 (Large)
Sierra Grande Models – Running Board Detail, Piping Location & Support, Reverse Gear, Tanks (2) Right & Left
Sierra Grande Models Frame 1:1 DM
Sierra Grande Models – Running Gear, Connecting Rods, Main Rods, Valve Gear, and Cross Heads
Sierra Grande Models – Tender Frame & Brake System, Foot Rest, Water Scoop, Tank
Sierra Grande Models – Cab Assembly
Sierra Grande Models – Boiler Cover Layout & Location
Sierra Grande Models – Half Pattern For Boiler Cover
Sierra Grande Models – K4 Boiler
Sierra Grande Models – Smoke Box Front
Sierra Grande Models – Cab Top And Side Flat Pattern
Sierra Grande Models – Steam & Sand Domes
Sierra Grande Models – Rear End View Of K4 Tender
Sierra Grande Models – Front View Of K4 Tender
Sierra Grande Models – Half Pattern Of Forward Boiler Shell Cover
Sierra Grande Models – Pilot Cow Catcher Construction
Sierra Grande Models – Half Pattern Of Mid Section Boiler Cover
Sierra Grande Models – Tender Tank
Frame 1:1 JP Redrawing (CAD)
Small Format Drawings (8 ½ x 11, 11 x 17) Sierra Grande Models
Trailer Truck Support Beam
Journal Box
Valve Gear Package (Several Drawings)
Air Compressor Package (Dummy) (Several Drawings)
Pilot Truck Package (Several Drawings)
Piping Arrangements Package (Several Drawings)
Valve Adjusting Tool
Boiler Package (Several Drawings)
Tender Truck Package (Several Drawings)
Throttle Control Assembly
Tender Tank Details
Reversing Gear Cross Head Guide / Mount
Valve Chamber Forward Head
Reversing Gear Lever
Packing Gland Wrench
Back Cylinder Head
Forward Cylinder Head
Cross Head Guide
Slippers
Piston
Piston Rod
Main Driving Rod
Link Block, Radius Rod, Slider
Eccentric Rod, Lap & Lead Link, Combination Lever, Crank, Crank Pin, Shifting Link
Combustion Control Drawings
Assembly Stand
Trailer Truck Accessories Package (Several Drawings)
Drivers, Axles, Bearings Journal Box Fit To Frame Section Package (Several Drawings)
Journal Box Binders, Short and Long
Engine Frame Accessories (Several Drawings; Pilot Pivot, Frame Rear Termination, Pilot Beam…)
Weight Boxes
Trunnion
Eccentric Crank
Eccentric Rod
Radius Rod Hanger
Radius Rod
Front Boiler Brace
Cross Head Guide Hanger
Inside Lift Bearing
Rear Boiler Mount
Cylinder Casting Boring
Trailing Truck Support
Universal Brake Cylinder & Assembly
Rear Frame
Valve Rod, Gland, Valve Rod Crosshead Guide, Crosshead Bearings
PRR Frame 1942
PRR Frame 1927
PRR Valve Gear 1926
PRR Side Rods 1939
Journal Box
Tender Tank Details
Back Cylinder Head
Cross Head Guide
Slippers
Piston
Piston Rod
Main Driving Rod
Assembly Stand
Weight Boxes
Trunnion
Eccentric Crank
Eccentric Rod
Radius Rod Hanger
Radius Rod
Front Boiler Brace
Inside Lift Bearing
Rear Boiler Mount
Rear Frame
Re: K4 Build
The cylinder castings jpeach is selling were used in the K-4 chassis shown in the attached video.
https://www.youtube.com/watch?v=ET4yq-U08Cg
- Dan Willey
Re: K4 Build
Hi jpeach,
Are most of these castings from Mercer? If not, what/who is their origin? Who cut the frames? (Everything is nice looking!)
Thanks,
Dan
Thanks,
Dan
1/8 scale: Mercer Locomotive K4, Saturated Steam E6
Full scale: Woodings CBL speeder/motorcar NARCOA
Re: K4 Build
Hi Dan,
The cylinder castings were produced by Dan Horting with help from Dave S. It is very nice, and Dan (ebtfan) has posted wonderful build pictures, so I know he has some more photos of the casting and machining process. I'm happy to take additional photos of any details (of anything). I'm unsure of the origin (maker) of the driver castings, although they are the same drivers that Dan Horting has used on his K4. The pilot / tender wheels were purchased from Dave S a couple of years ago along with the spoke trailer truck wheels and the bronze brake cylinder castings.
The frames were laser cut from hot rolled plate at Yoder industries in Lancaster. I machined the journal pockets and the pedestal binders. I believe I documented the machining of these in the small build thread I had started. The spacing and width of the journal slots is dead on with the prints.
The two CNC cut brake hangars were done by me also and they turned out nice. I made a set for Dan Horting and they are in use on his chassis.
I should have included in my original post that of course anyone interested is welcome to come by my shop to view everything and pick up if they would like. Even if you are just considering you are welcome to come check everything out.
I live in Hampstead MD 21074 in Northern MD, south of York PA.
I prefer to sell as a package , and just have it listed on the Chaski site for now.
Thanks,
Jim
Thanks,
Jim
Re: K4 Build -Sold
Package is sold pending pickup next week. Thanks to everyone who inquired and commented. Much appreciated, Jim
