RMI 65 ton Center cab industrial switcher w/side rods, 2.5” scale, 7.5” gauge
Solid riveted cab; All steel construction; Axle-mounted, heavy duty industrial gear boxes; 5/8 hp, continuous-duty 24 volt DC motors; Solid-state programmable control and power modules; Phoenix sound system with 10”woofer and 2 smaller speakers; LED headlight w hi and low; AGM 12 volt wheel chair batteries (4 in loco, 2 in control car),; Battery Minder Maintenance charger-desulfator, model 24041, 24 volt @1-2-4 amps; RMI Loco controller model 2000 w/ 10’ cable; Knuckle coupler front, Tom Bee Knuckle draw bar back connecting to the control car.
Control Car
Drop center all steel, welded control car with expanded wire mesh floor in drop center, Tom Bee 1.5” scale, 7.5” gauge, heavy duty, 6 spring trucks with brakes and rear coupler. Simulated crate w/ two more 12 volt AGM batteries, a boat seat w/ a swivel base. Stand for controller w/ attached Tom Bee brake control system. Safety chains rear.
Riding “T” Car
5.5’ long X 16” wide. Tom Bee couplers, trucks w/ brakes, and safety chains; Air compressor, regulator and tank built in under bench seat for train line brake supply; Rerailer stowed on car – a wheelbarrow handle and pedestal.
Riding Caboose
2.5” scale, 7.5” gauge; 5.5’ long X 20” wide; independent brake system for parking on an incline - with compressor, regulator and controller that can be set by RC from loco; Red tail light; Forward facing red light that indicates when caboose brakes are set; Tom Bee couplers, and trucks w/ brakes. Removable boat seat; 12 volt battery and charger.
Take home this whole train for $11,350. Come for a test drive in Canton, GA. Will separate, but the best deal is the whole train. We are selling this for a member of our group whose back problems prevent him from enjoying the ride.
Come for a test drive in Canton, GA. Will separate, but the best deal is the whole train. Rail lift hoist available to load in your vehicle.
Use this contact: Charlton Jones Email: cj.trainerATjuno.com (use @ for AT)
RMI 65 ton Center Cab and 3 Cars
Happy Rails !
RichD
Colorado Midland Ry Ten Wheeler U/C
Kerr Stuart Wren NG 0-4-0 U/C
www.csppry.org
Imagination is your best tool.
RichD
www.csppry.org
