Model Steam Pressure Gauges
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Moderators: Harold_V, WJH, gwrdriver
apm
Post by apm » Thu Oct 10, 2019 10:09 pm
With the help of fellow board member Mike McCotter we came up with the following steam pressure gauges;
In the first round we made up 10 of these so they are first come first serve, but if the demand is there we hope to make more.
Basic specs, the dial comes in at 2" in diameter, bottom is threaded for 5/16-27mtp threads. I have a limited quantity of 3/16" dia tube fittings that can also be included with the gauge.
Price is $150each + $8 Shipping in the USA, fittings are available for $10extra.
If interested best to send money via my paypal adam@miller4.org
Thanks,
Adam
765nkp
Re: Model Steam Pressure Gauges
Post by 765nkp » Thu Oct 10, 2019 10:34 pm
Is the overall diameter 2 in or is the dial face alone 2 in? If so what is the overall diameter?
Very nice looking!
Tim
Howard Gorin
Post by Howard Gorin » Fri Oct 11, 2019 1:48 am
What about different pressure ranges? 250PSI, 200 PSI
wbarbe
Post by wbarbe » Fri Oct 11, 2019 2:40 pm
I have always been told your gauge should be about double your working pressure. Don't most models run about 100-125 PSI? So a 200-250 PSI gauge would be ideal.
Am I off base on this?
prlawiii
Post by prlawiii » Fri Oct 11, 2019 6:29 pm
What would shipping be to Canada? I would think it should fit in some kind of small flat rate box.
Thanks,
Herman
Just starting an Allen Mogul
renewing a Marie Estelle
apm
Post by apm » Fri Oct 11, 2019 9:13 pm
To answer a few questions;
Tim 2" is the dial face itself measured at the largest diameter of the bezel. The case itself is is nominally a little larger than 1.5" the whole gauge stands about 1-1/16" tall.
Howard, it seems like last time this came up the consensus was most guys wanted something in the 300psig range. I can do them right now in the 160psig range, and the gauges I use to start with are also available in 200psig if there is interest in getting artwork built up around that pressure range too. 250psig may take a little more R&D to figure out a good and simple gauge to use for the cause.
Herman, I just looked up shipping to Canada I think $15 should probably do it.
Adam
Fender
Post by Fender » Fri Oct 11, 2019 10:09 pm
Adam,
I just sent money through paypal; please confirm that it came through.
Dan Watson
Dan Watson
JTolan
Post by JTolan » Fri Oct 11, 2019 11:44 pm
Money sent. Looking forward to it.
apm
Post by apm » Sat Oct 12, 2019 6:58 am
I ran out of the compression fittings for now, but still have 5 gauges available. Dan and Jeff they should go out today.
Fender
Post by Fender » Sat Oct 12, 2019 8:45 am
Thanks! Eager to see the gauge.
Dan Watson
apm
Post by apm » Sun Oct 13, 2019 3:19 pm
Just an update here, I am now all sold out, hopefully we will do another run sometime in the not too distant future, if not even expand on the line altogether.
Fender
Post by Fender » Sun Oct 13, 2019 4:30 pm
Adam,
Will you be restocking the 3/16” tube fittings, or do I need to find one elsewhere?
Thanks, Dan
Dan Watson
