Here is the listing for the "Simulated Arch Bar" castings. It also list the castings to make trucks for 4 3/4" and 5" guage.
It also list PLA Patterns for sale.
http://newproductllc.com/railway-truck- ... nch-gauge/
Rapid build RR truck castings listing
Moderators: Harold_V, WJH, gwrdriver
Re: Rapid build RR truck castings listing
Interesting. They list the archbar trucks as being 6061 aluminum, but that is a wrought alloy designation... I am curious as to what alloy it is. Since it is still on the gating, I would suspect that they have not been heat treated - but it is possible that they put the full casting in the heat treat oven also...
That's a good observation.
In defense work, it's not uncommon for obsolete parts being remade. I worked at a facility where that was the case. The parts required were apparently originally made from 6061, but the replacements were cast from the same material (in lieu of fabricating from bar stock), but with mixed results, as 6061 does not cast as well as materials intended to be cast. Your questions are well founded.
It should be noted that if a heat treatable aluminum is in the solution annealed state, it will self harden over time. Hardening, in this type of material, is caused by grain growth, and can be accelerated by proper heat treatment.
