New from the Backshop
A customer recently asked me to machine up a dummy stroker engine and crank housing assembly for his locomotive. I decided to do two of them while I was doing his, here is the second one I'm putting it up for sale. It is a fairly heavy unit all brass castings, the body and crank housing are sand cast brass and the stroker heads are investment cast brass
This is a great detail addition to any locomotive as it mounts under the cab to the floor and is a great way to hide water or air lines, brake controls or electrical connections and keep them away from the heat of the fire box
Price $325.00
I have one in stock and if there is interest I will make more
You may also order it as a casting kit, or I can machine just the engine and head assembly with no crank housing for you
Please email me at highiron@aol.com to order.
please include your complete name mailing address and and phone number
item will be sent USPS
Thank you for your support
Mike Venezia
1.5 / 1.6 scale dummy stroker engine and crank housing
Moderators: Harold_V, WJH, gwrdriver
