Accucraft is starting production of Cast Steel Frogs. These new, Highly detailed frogs are for the West Coast Profile. We have at this time the number 4, 5, 6, 7, 8, and 9 ready to go into production. We will be following up with highly detailed Cast Steel Points, and shortly there after, we will be offering some switch kits. We will be publishing the design specifications for all the frogs to build lefts, rights, and wye's with these frogs and points. The pre orders will be opening soon, we just need to get a few things in place first. If all goes according to plan, the frogs should be ready by late winter or early spring. Here are the drawings for the frog's Note: rails are attached with rail joiners!
Note: Once past the frog heel in a switch, the radius can be adjusted to a larger or smaller radius to fit your need.
Your input will be greatly appreciated. It will let us know how many of each size to bring in on the first production run.
Contact: David Coster for more information
mikados@mac.com
New Patterns for Frogs.
