Hi all,
I'm getting ready to make a throttle quadrant for a LE 0-4-0 in 1.5" scale...Just the curved piece the the throttle rod is guided by. I'm going to use 1/8" steel flatstock, bead blast and shine them up a bit....Does anybody need one for any projects in the forseeable future? $20 each...
I'll try to take a pic when I get one made....
Thanks,
Andy Pullen
Anybody need a 1.5" scale throttle quadrant?
Re: Anybody need a 1.5" scale throttle quadrant?
Andy:
Would that be a configuration I could use on the Allen Mogul?
Neil
Neil
Editor Emeritus - Live Steam & Outdoor Railroading
Allen Mogul under construction
Electric RS3
Stationary Steam
Electric RS3
Stationary Steam
Hi Neil,
I made 4 of them yesterday afternoon. I only need one for the engine I'm building for a client. Attached is a pic of them next to a scale and a quarter. As I said, I only have the parts in the pic for sale.
I don't see why you couldn't use it on an Allen locomotive. I can run a copy of the full print with the other parts for you if you want. There is one casting and a bunch of little pieces of flat stock in the assembly.
Andy Pullen
Andy Pullen
Hey Neil,
Here's the finished assembly. I could be persuaded to make the rest of the parts if you want one. The hole through the middle of the base piece is 1/2" diameter...That should be plenty of material to machine to fit whatever sticks out of the end of the staytube....
Andy
Andy
Andy,
I would be interested in one of your quadrants for my Allen Mogul. PM me the cost.
JD Johnson, Morehead and North Fork Railroad Historian
Hi all,
I'm cuttlng material for some more of throttle quadrants....One is spoken for....Anybody else?
Andy Pullen
Andy Pullen
Everyone,
I just received my quadrant and am very very pleased with my purchase.
It saved me lots of time indeed.
Thanks Andy!
Thanks Andy!
