Wanted 3/4 inch Live Steam Engine
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Moderators: Harold_V, WJH, gwrdriver
Brian Tusin
Post by Brian Tusin » Sun Jan 30, 2011 9:26 pm
My 3/4 inch Bonds Royal Scot needs a lot more done to the running gear then I had thought and I am really over my head in what it requires. So what I am looking for is a running or close to running 3/4 inch Atlantic, Pacific, Hudson, or similar sized engine. You can contact me through a PM on this site or my email address. viperbpt@yahoo.com
Thank you,
Brian
Brian Tusin
Re: Wanted 3/4 inch Live Steam Engine
Post by Brian Tusin » Fri Feb 18, 2011 6:54 pm
I still have not found a locomotive yet so if anyone knows of a 3/4 inch steam engine or even a 4 3/4 inch engine for sale I would be interested. I have seen the 3/4 inch 2-4-0 for sale on Discover Live Steam but I would like something a bit bigger than it. Brian
Post by SteveM » Fri Feb 18, 2011 8:41 pm
How about seeing if anyone here can fix your existing engine?
Several people here do that kind of "rehab" work.
Andypullen
Post by Andypullen » Mon Feb 21, 2011 9:44 am
What's the problem with your locomotive? What part of Ohio are you in?
Andy Pullen
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30", Sanford MG 610 surface grinder, Kalamazoo 610 bandsaw.
Brian Tusin
Post by Brian Tusin » Tue Feb 22, 2011 6:41 pm
Andy,
It pretty much needs new bearings on all of the axles, most likely a new rear axle as coal soot got into the bearings, new rod bushings, new piston valves, pistons, the cylinders bored (they have scratches in them and the engine had a TON of blow by when I ran it), and a new boiler. I did not get to see it run before I bought it, and trusted the only thing wrong with it was a problem with the lubricator which was an easy fix. Plus I would like to do the work by myself. Right now I do not have the tools or experience to be able to do the work.
Brian
Andypullen
Post by Andypullen » Wed Feb 23, 2011 7:26 am
Hi Brian,
I'm sending an email to the above address....
Andy
Marty_Knox
Post by Marty_Knox » Wed Feb 23, 2011 1:56 pm
Andy, I inspected the boiler for Brian. I don't have my notes in front of me, but it really does need a new boiler. The top of the Belpaire firebox was bulged between the stays. If I remember correctly it had a ..093 outer wrapper with a .125" inner firebox. The crown stays are .187" dia on a 2" spacing, and I seem to recall it was 3" or more from the front of the firebox to the first crown stay.
Andypullen
Post by Andypullen » Wed Feb 23, 2011 5:56 pm
Marty_Knox wrote:Andy, I inspected the boiler for Brian. I don't have my notes in front of me, but it really does need a new boiler. The top of the Belpaire firebox was bulged between the stays. If I remember correctly it had a ..093 outer wrapper with a .125" inner firebox. The crown stays are .187" dia on a 2" spacing, and I seem to recall it was 3" or more from the front of the firebox to the first crown stay.
Sounds like a new boiler to me, too....Seems like the stays are awfully far apart for a copper boiler, too...
Andy
Brian Tusin
Post by Brian Tusin » Sun Jul 10, 2011 8:35 pm
I am still looking for a running 3/4 inch engine if anyone has or knows of one for sale.
Brian
Joe Tanski
Post by Joe Tanski » Mon Jul 11, 2011 7:33 am
Brian : I have a 1" sacle 4-6-0 Royal Scot for sale ,copper boiler,axle pump , injector,build by Henry Hosper's of FLL club
back in the 1965 outside walschaert valve gear, new pistons & rings last winter 4 3/4 " gauge + riding car with pad brake,engine has steam brakes , needs paint job
if interested contact me
Joe
Post by Bill Shields » Thu Jul 14, 2011 6:47 am
If a 2-4-0 is a bit small for you, then I guess a TICH would be out of the question... :lol:
Brian Tusin
Post by Brian Tusin » Fri Sep 02, 2011 4:22 pm
I am still looking for an engine. I will be at the NJLS meet at the end of the month. Any help in finding and engine would be appreciated.
Brian
