More trinkets from the basement "ALL SOLD"
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Moderators: Harold_V, WJH, gwrdriver
Postwarbob
Post by Postwarbob » Mon Sep 26, 2011 11:33 am
I have been given these items to consign for a friend. I have inspected each piece and they are all in exc condition and RT use except for one set of cylinder cocks that need new diaphrams. The pricing is firm and I based it on todays market price.
Item #1-4 ea steam operated cylinder cocks. The body is 7/8" in diameter and they are about 1 " in height .The rubber diaphrams need replacing. they have a bronze disk in them that seals under steam. Threaded 1/8 pipe Sold !!!!!!!!!
Item #2 is 4 ea Manually operated Cylinder cocks. They would fit great on a 4-4-0 american or other. SOLD !!!!!!!!!!!!!! Item #3 is 4 ea steam operated Cyl cocks . I believe they are from RR Supply 3/4" in Dia. 1" in Height 1/8" pipe . There is a manifold that ties them together that is inc. They have a brass diaphram with a brass disk for sealing. Used but in exc condition. SOLD !!!!!!!!!!!! Item #4 is 4 manually operated cyl. cocks. 1/8" pipe L/n Condition 50.00 set of 4
Item # 5 is 2 each 3 way exhaust valves used on steam operated cylinder cocks. Both Are Sold !!!!!!!!!!!!
Item # 6 is a 5/16" MTP injector starting valve sold by Super Scale. Used but in exc condition. Sold !!!!!!!!!!
don1102
Re: More trinkets from the basement
Post by don1102 » Mon Sep 26, 2011 12:39 pm
PM Sent!
Loco112
Post by Loco112 » Mon Sep 26, 2011 4:09 pm
When you say "manually operated", do you mean that steam pressure (to them) opens the cocks?
What brand are they, any idea?
Narrow Gauge (Information) Exchange dot Org forum
My Projects:
Davenport 30 ton diesel (SV#101 / D&RGW#50)
C&S 1908 steel & 1905 wood: box, stock, flat, gon
D&RGW wooden freight cars, long & short cabeese
EBT 2-bay hoppers, Conoco #44 tank
DV (K&J) hopper
8"n3 - 3-footers, 8" scale, 24" gauge
Postwarbob
Post by Postwarbob » Tue Sep 27, 2011 8:31 am
The outer ring rotates around the stem . It has an arm with a hole that linkage attaches to. As it turns it opens the hole for drainage. Pretty simple design . I beleieve they were homemade. Bob
