Up for sale is a Allen 10 wheeler or Mogul style tender tank. It would work for many other smaller size engines also. It is an extra that I had left over from a batch of 3 that I built. Dim's are 14 1/4" wide by 35" long at tank and 39" at floor. It is not currently sealed but can be for additional cost. Can also cut water hatch opening if you like.
Asking $875, sealing would be another $50
Buyer pays shipping and packing
Thanks
Tim
trmikko@sbcglobal.net
314 401 9497
1.5 inch scale Allen Model style tender tank
- makinsmoke
Re: 1.5 inch scale Allen Model style tender tank
Tim,
What size rivets did you use and are the top rivets soldered at the sides? I assume the top is screwed on as per the prints?
Any holes drilled in the floor?
Thanks,
Brian
Thanks,
Brian
Brian
The rivets are 3/32, and the top is screwed on. There are no holes in the bottom for mounting at this time.
Buyer can add them or I would be happy to drill them.
Thanks Tim
Thanks Tim
This tank has been sold, but I can build more. Just let me know what your looking for.
Thanks Tim
Thanks Tim
I am interested in a tender for a 10 wheeler. Im am tall guy and might like it be litlle longer for ride comfort. Give me PM and we can talk details.
Thanks, Rob
Thanks, Rob
Tim,
I take it that is made of steel. I am not a lover of steel. I made most out of brass. But now I am out of brass!!!! How are you doing the rivets? Are they soldered in or hammered. Is the top removable for working inside for water valves and mounting to the frame, etc.
I am working on an Allen mogul and it is about 2-3 months from done. I have all the castings and rails for the tender except trucks and no body. Was thinking of getting a fiberglass from LE.
Would you email me direct ( bgsberk@comcast.net ) as to when one could be available and cost + shipping to 19403 in SE PA. I would use gas tank sealer for the inside.
Thanks, Bruce
Thanks, Bruce
