WTB: "Industrial" looking 6.625"D finished tread wheels
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Moderators: Harold_V, WJH, gwrdriver
Benjamin Maggi
Post by Benjamin Maggi » Wed Apr 18, 2012 8:48 am
For a Sweet William project I am pricing out, I am looking for a set of four drivers. In 5" gauge they are finish machined at the tread to 4.625", so I imagine for 7.25" gauge they will machine to around 7." EDIT: They are 7" diameter over the flange, but 6.625" diameter on the treads. (I am not sure as I only have the 5" gauge Sweet Pea book currently- the plans for the Sweet William are on order).
The wheels are essentially discs with a raised area for the crankpin and two holes, either for balancing or just for looks.
There is one gentleman who sells laser-cut parts for the Sweet William but his prices seem a bit steep plus they include other parts that I don't want. Does anyone offer basic drivers, spoked or solid with raised crankshaft area, that would be suitable for this project?
(Pictures of the wheels here: http://www.duncraigworks.talktalk.net/)
Thanks.
Last edited by Benjamin Maggi on Mon Dec 10, 2012 11:35 am, edited 2 times in total.
makinsmoke
Re: Inquiry about 7" finished tread wheels availability
Post by makinsmoke » Wed Apr 18, 2012 11:11 pm
Beej,
Railroad Supply shows a B-5011 drive wheel 7" diameter, 3" stroke in their catalog....
B
Benjamin Maggi
Post by Benjamin Maggi » Thu Apr 19, 2012 1:48 pm
Thanks. I would know that except when I tried to order a catalog from them several years ago I was told that they didn't sell catalogs anymore. I will give them a call.
Does the 3" stroke mean that the raised crankpin area is 3' from the center of the wheel?
makinsmoke
Post by makinsmoke » Thu Apr 19, 2012 2:18 pm
I'd be afraid to touch that one, although I'd "guess" it was the finished crankpin centerline to centerline as the wheel is rotated.
Probably wrong, though.
Post by Harold_V » Thu Apr 19, 2012 2:59 pm
Benjamin Maggi wrote:Does the 3" stroke mean that the raised crankpin area is 3' from the center of the wheel?
I would expect that it would be half that. Otherwise the stroke would be doubled. (I'm assuming the 3' is a typo)
shayloco
Post by shayloco » Thu Apr 19, 2012 4:04 pm
3" stroke means that the center of the crankpin is 1.5" from the center of the wheel.
As the wheel turns the crankpin will move through a circle of 3" diameter. Via the connecting rod, crosshead and piston rod this 3" of motion is transferred to the piston, resulting in a stroke of 3".
-Larry
makinsmoke
Post by makinsmoke » Thu Apr 19, 2012 9:00 pm
Thanks Larry!
That's what I meant but you said it with so much more clarity....
Brian
Pontiacguy1
Post by Pontiacguy1 » Mon Apr 30, 2012 2:58 pm
The Little Engines 0-4-0/0-6-0 switcher wheels are 7" in diameter, with 13 spokes. They have them in both 'light' and 'heavy' counterweighted versions. They are made for a 3" stroke (1 1/2" crankpin to axle center), but I believe that you could make it up to 3 1/4" stroke if you were careful, and definitely less if need-be. I have used these wheel castings several times.
