one piston heat engine tips
This forum is for Internal Combustion Engines such as Hit 'n Miss, Throttle Goverened One Lungers etc. Repair, Machining, Operation, Buy/Sell/Trade of these engines are all topical.
hotwiredu
Post by hotwiredu » Mon Feb 06, 2006 5:27 am
Any one have tips for building one piston heat engines,glass metal, or others.
you cant get there from here
Bud
Heat engine
Post by Bud » Tue Mar 21, 2006 8:32 pm
Do a search for Sterling engine
Orrin
Post by Orrin » Wed Mar 22, 2006 10:27 am
If you are wanting information about a hot air engine, do a search for Stirling engine, not Sterling engine.
Lindsay sells plans for the one piston hot air engine. The title is "Building Stirling 1" by E.T. Warbrooke.
Orrin
So many projects, so little time.
lynmn
Single piston heat engine
Post by lynmn » Wed Apr 11, 2007 11:21 am
Try this web site http://www.stirlingengines.org.uk/ Browse around and you will find pictures of the single piston engine that use a test tube and a bit of scouring pad for regenerator. Is this what you are looking for? If so send me an Email, I will send you a picture and specs. of one i have built. It runs along a good speed. Lynmn
gary350
Post by gary350 » Sat Oct 10, 2009 11:04 pm
Plans make it easy to build an engine. I have an original sterling engine built about 1915. I spent 2 weeks making detailed drawings of the fan and all the parts. I have used the plans to build 3 more hot air engines. Each one is a little different but the basic 2" bore engine is the same.
http://www.youtube.com/watch?v=J56D56rQV-Q&NR=1
http://www.youtube.com/watch?v=NBpRl5eF ... annel_page
http://www.youtube.com/watch?v=57GFrxz_ ... annel_page
http://www.youtube.com/watch?v=iSBXcn4u ... annel_page
