(Re: 2.5" scale)
Fender wrote:Generally the equipment is more ergonomically-friendly to the operator
jcbrock wrote:What I really like about 2.5" is also like Dan, the size of the cab. I think they are much easier to run than the 1.5"/1.6" because you can get your hands in there easier.
Kimball McGinley wrote:I chose a 2-1/2" scale locomotive because it is far more simple to build than a 1-1/2" model of comparable size and weight. I can build an 0-4-0 instead of a 4-6-2, for example - less wheels, simple suspension etc.
There's some of the appeal of it - larger cab/controls, wider cars for more comfortable rider-cars, and potentially simpler engines. Plus, if I ever feel ambitious enough to attempt a scratchbuild (not from casting kit/plans), I'd seriously consider a ET&WNC narrow gauge ten-wheeler.
Pontiacguy1 wrote:I do like the narrow gage, but things like trucks, couplers, detail parts, etc... are more expensive and there is less stuff available. That being said, more stuff seems to become available fairly frequently, so things are catching up. One of the Main things to me, my trailer will handle, on the floor level, a medium size locomotive and tender, and about 7 freight cars in 1 1/2" scale. I could probably only get about 1 locomotive, the tender, and about 4 cars in 2 1/2" scale. Also, I can re-rail a 1 1/2" scale car by myself really easily.
This sums up my narrow-gauge concerns pretty well... expensive parts, when parts are available.
Pontiacguy1 wrote:My main advice would be to pick a scale and then stick with it.
That's kind of the point to this thread. I would like to pick a single scale, but will I get frustrated with the limitations of one particular scale? I like the apparent availability of 1.5" scale equipment, but the larger equipment appeals to me too... if I take up 2.5" scale, maybe someday I'll build a narrow gauge ET&WNC 12 (4-6-0) or similar.
mattmason wrote:I have 1", 1.5" and 2.5" scales. I prefer the smaller because it is far easier to move around and I can fit more equipment into my truck. The smaller sized feel more like modeling to me, but some guys love the feeling of working on a flu-size loco so they go bigger. As I get older, I like being able to move my stuff around easier with the smaller stuff. AS I get older, I appreciate the more comfortable ride of the larger.
As you can see, there is no one perfect scale, just what tradeoffs you prefer over the others to make the size that's right for you.
I'm trying to resist the urge to go multi-scale. But I do like there's more stuff available for 1.5" scale. More "entry level" type kits.
