Bicycle brakes can clamp on the edges of the wheel treads for a parking brake too.
Mike
Solenoid Actuator for Parking Brake?
- Erskine Tramway
Re: Solenoid Actuator for Parking Brake?
Former Locomotive Engineer and Designer, Sandley Light Railway Equipment Works, Inc. and Riverside & Great Northern Railway 1962-77
BN RR Locomotive Engineer 1977-2014, Retired
They also make a bicycle disk brake.
- tornitore45
Brakes need very little travel, therefore leverage can be used effectively to multiply the force.
In addition a solenoid pull force gets progressively stronger as the gap closes, a fact that matches the low force requirements during the brake free play getting progressively higher at the break tighten. I believe a solenoid no larger than a wine bottle cork will do.
Mauro Gaetano
in Austin TX
in Austin TX
