Remotoring a Koster's Miniature Railroad Supplies Locomotive
Hi
I just receive a Koster's Miniature Railroad Supplies, Inc. Locomotive. The trucks need a complete rebuild. I need to replace the WWII surplus motors and am looking for recommendations for new permanent magnet motors and a new control system.
Tim
Tim
Re: Remotoring a Koster's Miniature Railroad Supplies Locomo
Tim,
It might make a difference on what size / model locomotive you have--trucks, no doubt four wheel.
Other than what has, and would be mentioned here about "scooter" parts or "other" motors and controllers I could give you his email off site if you would like. Might help for other repair info.
You might have Bill`s E address in the FLS state book.
chooch
chooch
The locomotive is a GP18. I will be putting 4 new motors and gear boxes on the axle as Bill designed them.
The motors that Bill used, are now 70 years old. They run at a higher RPM than the new permanent magnet motors that are available now. So the gearing will be different. So a new gearbox will have to be made.
I will be calculating for 8 MPH top speed. A 5" wheel will be turning 538 RPM at that speed.
MDM Locomotive Works is now using a 4" diameter 1/2 HP motor. That is 375 watts.
Tim
Tim
Hello Tim,
Two other possible sources come to mind. These are as follows:
Dave Gehrke...West Bend Trains/Locomotives (in Wisconsin...usually advertises in Disc Live Steam)
Tom Artzberger...Pike Lake & Eastern Shops (?)...now located in Colorado.
Both suppliers might be using transaxle mounted gearboxes with motors. Didn't know if having another possible source would help you. Good luck...let us know how the "re-motoring" works out. Carl B.
Tim,
I have a small catalog diagram that was actually for Friction drive gas motor. But I have made it to work for electric drive. Shows a shaft UP above the floor of the loco. Then down to another shaft crosswise Under the bolster to the side frames
From that shaft Outward are a chain to each drive axle. Yes, it is All chain and sprocket drive.
Yes, from up above and down to the truck it Will swivel.
I have both an Original (70`s) drive system and one made similar myself.
Also, have made my own motor mount brackets similar and, with same size Plum Cove motors and gears for Koster`s diesel trucks.
One motor each axle. I think the main difference would be the Wheel sizes. I only have Four inch, not Five.
If I can help--feel free to ask.
chooch
chooch
Thanks Carlccvstmr wrote:Hello Tim,
This is what I am looking for.
Tom Artzberger
HARTFORD SHOPS
- Attachments
its not exactly what you are looking for, being these are chain driven vs gear.
but these are the trucks i have fabbed yup for a pair of "budget build" locos i am building with a friend,
each truck has two 500 watt PM motors running a 4.05 to 1 ratio.
this setup may not fit the frames if they are 1.5 scale. but i wanted to scale as another option
I found that the Pike River Northern also make drive assemblies. As well as cast steel Blomberg Trucks.
Tim
Tim
Well I don`t see Plum Cove mentioned for motor/gear drive systems so here`s a link below.
A gear box--no but--with about 200 locos sold they say and, and the Many I have seen and some of my own locos without "covered" gear boxes running with no problems, on "Florida Sandy Soil" are they Really needed.
Better than none, no doubt. But all the "hype" about a gear "Box" is just that in My opinion. A natural selling point of course and, no offense to those that supply them.
Just an alternate point of view and way to build your own similar drive system more simply.
Thank you.
chooch
http://www.plumcovestudios.com/axles_01.html
A 6 to 1 gear ratio
Thank you.
chooch
A 6 to 1 gear ratio
