mechanical remote switch
All;
I am looking for examples of a mechanical linkage or mechanism to throw a switch from say 10 feet up the track using a harp stand. No electricity or air available.
Cable or rod mechanism inside a PVC conduit would probably work best. Just trying to puzzle out what the linkage would look like to get side to side motion to translate to back and forth motion along the track, then back to side to side motion at the switch. It would be nice to orient the harp as it would be if it were sitting next to the switch, perpendicular to the track. I think an "L" shaped bracket at least on the switch end might work.
Thank you,
-Mike
Thank you,
-Mike
Re: mechanical remote switch
Mike,
Just saw at Fair Weather Foundry he posted new remote switch throws.
I don't have any or have seen them but they sure look promising.
http://www.fairweatherfoundry.com/?page_id=202
Dave
Dave
Oh that's a good way to do it. Just need more vertical room underground, but eliminates more complicated geometry.DRS_RR wrote:Mike,
Dave
Mike,
PM me with your email address, I have pictures of the mechanisms from Portola Valley if that's something you would like to consider.
Matt
Matt
Can you say "bell crank"?Harlock wrote: Just trying to puzzle out what the linkage would look like to get side to side motion to translate to back and forth motion along the track, then back to side to side motion at the switch.
Bell cranks and rods were used to control turnouts from an interlocking tower on railroads up until around 1960. An operator in the tower would push or pull a long lever which actuated a rod running along track side linked to a series of bell cranks and ending at the turnout. These rods could be a hundred feet or more in length. Just a little history. I believe it is now done pneumatically.Harlock wrote:All;
Thank you,
-Mike
Mr.Ron from South Mississippi
- steamin10
The operator that I am familiar with, are electric worm screw operators. They have been around a while, and are quite bulletproof.
The old tower operators, not only had reach rods that snaked out to the switches, but interlock levers, that had to be thrown to release the switches. Those interlock levers controlled the signal lights to indicate the track changes to the main line. Thus the name interlock tower, and all the communications from the tower operator back to the Trainmaster. Most of the towers are gone and satellite takes care of the signals, with GPS tracking the head and tail of the trains. Really advanced since the days of the 60's and the end of elegant rail travel.
As for a ground throw, an 8-9 inch lever with a golf ball sized clunk weight,, is enough to hold a reach rod to a switch. Running parallel to the rails, the crank moves the points through a spring setup, to maintain pressure on the points, but will allow running through the spring points without problem. Teh reach rod can be extended past the points, and do the same for the approach, which must be aligned before entering. Really simple, a ten foot rod is only supported by three brackets of angle iron (Aluminum?) along its length. Rods can be painted steel, but SS wont give any problems. The end joints and crank connections are simply round slugs roll pinned to the rod
Finger Lakes Live Steamers has a few switches with remote operators to allow an engineer to throw a switch without getting off of the locomotive. They were designed and built by Hank M., who is a club member. They have a pulley at the bottom that pulls cables through a conduit. Stops on the stand prevent over throw.
You can see the stands in the following link for a Youtube video at 0:49 and 1:50.
https://www.youtube.com/watch?v=2NGAqwggwOk
Here is a link to a still photo from their website:
http://www.pbase.com/flls/image/136113496
I do not have exact details of construction but have used them and they work great. Unfortunately I do not have contact info for Hank but try emailing their board of directors to see if you can get contact info.
- Greg_Lewis
Back in 1961, Model Railroader had an article on how to design and build an interlocking switch mechanism. While it was scaled for use on HO or O, the idea could be enlarged. Looks like there is an update available on line:
http://mrr.trains.com/how-to/tips-proje ... cle-series
Greg Lewis, Prop.
